Nik911sc
Re: Apple Carplay
Fri Mar 29, 2019 12:39 am
My understanding is Apple has moved away from an authentication chip to software keys so looks like this initiative will change direction.
Priestrich
Re: Apple Carplay
Fri Apr 19, 2019 2:10 pm
actually i not tested yet but maybe u can install android auto onto pi and u just have to buy a “carplay usb dongle for android headunits” there are a lot on ali and etc.
Re: Apple Carplay
Sat Apr 20, 2019 7:17 am
I presume until someone pays £35.00:
https://www.aliexpress.com/item/32826755246.html
Then runs OprnAuto on a Raspberry Pi:
https://www.raspberrypi.org/magpi/andro ... -openauto/
Will never know if this workaround is feasible ????
adieu
pedrofp
Re: Apple Carplay
Wed May 15, 2019 7:35 am
I was under the impression that CarPlay is built around iOS Operating System, I do not believe anyone has attemped porting !
Nope! CarPlay is an API set that allows iOS apps that provide a CarPlay UI to be accessed on the CarPlay screen. Neither the hardware or software are from Apple, they're what the venders of CarPlay equipment, both OEM & aftermarket, choose to use. The apps accessed via CarPlay are running on the iOS device, just in the background on the device & presenting a UI on CarPlay. All of that applies to Android Auto as well. On equipment that supports both (which is most because vendors don't want to shut out potential customers), it's all on the same hardware with facets of the software addressing each API set.
Running CarPlay on Raspberry Pi is simply a matter of writing Pi code that fulfills the CarPlay API. The biggest block to running CarPlay on Raspberry Pi is having the API documentation.
Return to “Media centres”
