iKokomo
Putting Raspberry Pi in Antique Radio
Sat Apr 05, 2014 5:58 pm
EXCITED, getting my first Raspberry Pi today!! (and my first post) :)
Ok, So I know there is a tutorial for this out there but the situation I am describing is different.
I have an antique radio that I am trying to restore but it may take be a couple of years to do, so my goal is to put a raspberry pi computer, case and maybe a small 5 inch monitor with a bluetooth/wifi adapter and a bluetooth keyboard/mouse.
Now my questions are:
1. What is the best OS to add to this to listen to streaming radio, goggle music, and music that would be on the SD card?
2. Is a Class 6 SD card good enough? Or should I get a 10?
3. I would like to get some USB lights so the radio dial will light up and look neat. What are the best lights for that?
I do not want to remove the innards yet as I can get it working, just would take a while so making the dials work is not an issue. I just want the dial to light up.
Thanks a lot!
southpaw
Re: Putting Raspberry Pi in Antique Radio
Sat Apr 05, 2014 7:09 pm
http://volumio.org/
or
http://www.squeezeplug.eu/
are 2 of the more popular options,
both can be controlled via apps on a smart-phone or tablet,
volumio was previously known as raspifi, both can put out some decent audio when paired with a dedicated usb sound output (the onboard audio output on the pi sounds poor quality compared with a usb option).
iKokomo
Sun Apr 06, 2014 1:39 pm
Thanks! And for a good set (or even 1 larger) USB LED light(s)?
What is recommended?
Also is class 6 good to use?
vonzepp
Tue Apr 15, 2014 1:12 pm
If you radio has a PU/gram socket you can plug the pi in with banana plugs
irimi
Fri Apr 18, 2014 5:53 pm
Based on MPD: IP Radio with DPF/LCD support , bluetooth & LIRC remote control , MDP clients available for various operating systems , Wifi AP / Client Mode & much more :D :
http://sourceforge.net/projects/audiculapi
jelly_p
Fri Apr 25, 2014 10:34 am
You can run LEDs from the GPIO pins on the PI, there is no real need to get USB LEDs
Alternatively there are LED add on boards which plug on to the GPIO pins (eg the PiGlow from Pimoroni)
Return to “Media centres”
