yes but AudioEngine is not used for RaspberryPi, it works different internally (thats why there is no alsa installed/used too)milhouse wrote:Do these latest builds include the AudioEngine updates?
Please rephrase, here=/= hear etc lolVZoltan wrote:Airplay Audio problem via JACK (image via composite)
if i stream for eg. youtube to raspberry openelec from my iphone/ipad i can hear its sound, but if it is ONLY audio like any mp3 or Pandora app, cant here anything at all BUT te virtualization shows that the raspberry gets the audio!
anybody?
jasjeet wrote:Please rephrase, here=/= hear etc lolVZoltan wrote:Airplay Audio problem via JACK (image via composite)
if i stream for eg. youtube to raspberry openelec from my iphone/ipad i can hear its sound, but if it is ONLY audio like any mp3 or Pandora app, cant hear anything at all BUT the virtualization shows that the raspberry gets the audio!
anybody?
If i understood you are saying that when you play Youtube to OpenELEC you can hear the Audio and see the Video. But if you play a music file from the Music App on iPhone you only see the Visualisation but there is no Audio?
If so, yeah thats normal and audio only never worked.
Im not sure, i think it might be because of how music is stored on the iPhone. I think Music App may not ever work, apps that allow airplay of MP3's may work, i cant say for sure as im not a dev.VZoltan wrote:jasjeet wrote:Please rephrase, here=/= hear etc lolVZoltan wrote:Airplay Audio problem via JACK (image via composite)
anybody?
and never will be working?
hey ...Piminiuser wrote:Is there a central place for the 'newest' openelec xbmc build.
Now i have r11211.img Is this the newest? I searched on this form, but i guess there is no 1 place when i can find the build. Some build i download i have a lot of folders and files. The "r11211.img" i have is just a .img file. and i use win32diskimager to write the .img to the sd card.
can u share how to listen to audio via airplay from ios device?dom wrote:Not true. I have played (with airplay) music from iPhone in the past, and the audio played in XBMC with visualisation.
This was several weeks ago when I was doing my own builds, so xbmc can support it.
as i said in a post just minutes earlier...its likely to be an ALSA codec issue. That's why the menu sounds dont work. Video works because it uses different codecs to decode the video/audio together.VZoltan wrote:can u share how to listen to audio via airplay from ios device?dom wrote:Not true. I have played (with airplay) music from iPhone in the past, and the audio played in XBMC with visualisation.
thx
OpenMAX is used for audio when playing music or videos. ALSA is not involved.onetootreefor wrote:as i said in a post just minutes earlier...its likely to be an ALSA codec issue. That's why the menu sounds dont work. Video works because it uses different codecs to decode the video/audio together.
ahh ok thanks for the infodom wrote: OpenMAX is used for audio when playing music or videos. ALSA is not involved.
(but ALSA is used for key press sounds, which are currently disabled)
Thanks for the image.sparky0815 wrote:Hey there
If u want 2 GB or 4 GB SD card images of r11212 (03.06.2012) you can download it from my blog...
http://bit.ly/MnBG7j
greetings
All you need to do is apply the image to the SD card, thats it, no need to touch any files. Then just boot it.raspberrypivictim wrote:Thanks for the image.sparky0815 wrote:Hey there
greetings
I have copied it to a sd, but when I start de pi the screens is black, no image. I am using the composite video output. the sd and the tv works great with the debian image, so I think I must have forgotten something in the configuration.
I had copied the config.txt from the working debian but black screen is my only result. And had proved other images available from this forum users.
Any idea ? thank you very much in advance.
Hi, there's some info about this in the other thread:
