gimli
Re: OpenELEC Testbuilds
Fri Jun 22, 2012 7:42 am
For faster FANART browsing you can also try to enable :
http://wiki.xbmc.org/index.php?title=Us ... sfanart.3E
Be warned, this fanart format needs more space.
milhouse
Fri Jun 22, 2012 7:47 am
gimli wrote:For faster FANART browsing you can also try to enable :
useddsfanart is already enabled by default in OpenELEC (see /usr/share/xbmc/system/advancedsettings.xml).
texy
Sat Jun 23, 2012 11:30 am
solardust wrote:What is current status of wifi support, specifically for RTL8188CUS? There's already https://github.com/OpenELEC/OpenELEC.tv/issues/793 open but hasn't been updated recently.
I second this - its a popular wifi dongle, very small and ideal for the pi and OpenELEC.
Texy
marb
Sat Jun 23, 2012 3:54 pm
marb wrote:1. Some thumbnails, posters and fanart images are scrambled (known issue)
2. With sound over hdmi, when I end playing any video, there is short looped sound coming from the speakers (tut tut tut tut tut tut tut... and so on).
3. I wanted to change aspect ratio on my older 4:3 videos (zoom or stretch), but it doesn't work. When I changed pixel aspect ratio manually in custom preset xbmc just displayed black bars over the video without changing it's actual aspect ratio. The black bars are also covering subtitles and osd.
4. Youtube addon doesn't work for me. RPi just hangs when addon initialize streaming. Vimeo or other addons are streaming fine.
2. Here is part of log when playing (and stopping) video file. http://sprunge.us/Yhda
4. YouTube addon now works, but it displays 1-8 fps and there is no sound. After looking at logs, it seems to be the same issue as >>here<<. Stream is played with DVDPlayer.
sraue
Sat Jun 23, 2012 9:33 pm
Another short update (r11392):
http://sources.openelec.tv/tmp/image/op ... 92.tar.bz2
to update a older build without reinstalling see: http://wiki.openelec.tv/index.php?title ... g_OpenELEC
  • updated XBMC (including Thumbnail rotation and Overscan fixes) many thanks to 'gimli'
  • added experimental ALSA support, Menusounds and Music is now done via ALSA, this *maybe* provides USB speaker/soundcard support thanks to Gimli
  • Kernel linux 3.2.21 many thanks to 'bootc'
  • various other improvenments and fixes
It is again recommend to update the bootloaderfiles which you can find in the build in the folder 3rdpart/bootloader. This you can update locally via Windows/Linux or via ssh: please test your SD cards, the ALSA/Sound changes and XBMC in general and report back.
thanks
Stephan
sporocyst
Sun Jun 24, 2012 5:20 am
Installed r11392 and had to revert back to r11315. Many of my video files would no longer play. The loading message would showup in the bottom right and spin forever. If I hit "stop" then xbmc would lock up and I had to kill it.
Also, music stuttered very badly.
sparky0815
Sun Jun 24, 2012 7:49 am
r11392 images on http://sparky0815.de
:geek:
Twitter: @Sparky0815
Facebook Gruppe (RaspberryPi - Deutschland): http://on.fb.me/PnYE99
warhog
Sun Jun 24, 2012 9:36 am
short checked r11392 with ~5 movies (mp4, dts, ac3) and works fine so far.
another question:
the openelec boot splash is distorted a bit, seems like it was converted from 16:9 to 4:3 without correcting the aspect ratio, was that intended? i've got a notion that almost all tv's which are in use with openelec are 16:9.
warhog
Sun Jun 24, 2012 9:41 am
huh i just saw the audio system settings show two new options:
receiver supports truehd/dts-hd :D
is that feature allready completely built-in?
warhog
Sun Jun 24, 2012 10:27 am
some more testing:
not able to play any mp3 over nfs. hearing no music and the time starts at 0:00, jumps over at 0:05 and goes straight back to 0:00
log:
12:25:50 T:1187681376  NOTICE: Thread Background Loader start, auto delete: false
12:25:54 T:1307153504  NOTICE: Previous line repeats 2 times.
12:25:54 T:1307153504  NOTICE: Thread CFileCache start, auto delete: false
12:25:55 T:1161647200   ERROR: CAESinkOSS::Initialize - Failed to get supported formats, assuming AFMT_S16_NE
12:25:56 T:1315542112  NOTICE: Thread PAPlayer start, auto delete: false
12:25:56 T:1161647200   ERROR: CAESinkOSS::Initialize - Failed to get supported formats, assuming AFMT_S16_NE
also images over smb do not work.
xbmc gui freezes when switching folders, top shows a load of ~3%
log:
12:09:05 T:1299903584   ERROR: GetDirectory - Error getting add
12:09:09 T:1100169216   ERROR: Control 18 in window 10129 has been asked to focus, but it can't
12:09:32 T:1100169216   ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://WS%2d3/tobi'
                                            unix_err:'d' error : 'Permission denied'
12:09:41 T:1291514976  NOTICE: Thread Background Loader start, auto delete: false
12:09:41 T:1291514976   ERROR: GetDirectory - Error getting add
12:09:43 T:1291514976  NOTICE: Thread Background Loader start, auto delete: false
12:09:47 T:1291514976   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
12:09:50 T:1156326496   ERROR: Previous line repeats 1 times.
12:09:50 T:1156326496   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
12:09:51 T:1291514976   ERROR: Previous line repeats 50 times.
12:09:51 T:1291514976   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
Vuk
Sun Jun 24, 2012 11:03 am
=> mh, check your permission?
smb://USER:[email protected]WS%2d3/tobi
warhog wrote: also images over smb do not work.
log:
warhog
Sun Jun 24, 2012 12:16 pm
Vuk wrote:unix_err:'d' error : 'Permission denied'
did so, this is because i'm not saving the password so it reasks again on each connect.
i'm seeing all entries of the shares root folder, but as soon as i want to switch into
a subfolder the gui freezes.
Vuk
Sun Jun 24, 2012 12:33 pm
maybe different permissions for the subfolders?
warhog
Sun Jun 24, 2012 1:25 pm
Vuk wrote:maybe different permissions for the subfolders?
no sorry, browsing the share and watching the images with my
laptop (ubuntu 12.04) works like a charm.
podly
Sun Jun 24, 2012 2:12 pm
In 11392, If audio output is set to analog, all menu sounds and music except videos goes via hdmi, no analog. Is it OK? Whether this will change if I connect external sound card?
Lightning303
Sun Jun 24, 2012 3:01 pm
trying out r11392.
cant really playback my videos anymore, tired to watch a tv series yesterday, and after 30 seconds it stutterted like crazy (720p h264). Also tried playing back my testing video which worked on old versions, couldnt start it at all. It says "Working..." for a while and then freezes (1080p h264).
Also, i tried to delete my Thumbnails folder so xbmc could fetch the pictures again (problem with scrambled pictures) and it says that i cant delete it, because /storage is read only filesystem?
i have connected my pi via hdmi to my av receiver. so i am using passthrough audio. while in menu my receiver is trying to get a lock on the sound again and again (HDMI logo is blinking on my avr) giving me a silent popping sound from my speakers. sometimes however it lookes like it gets a lock and my avr is showing the HDMI logo (not blinking) and PCM logo, when browsing the menus however, i loose the lock and it tries again (menu sounds are off).
keep up the good work, realy like openelec ;) thanks.
humla
Sun Jun 24, 2012 3:11 pm
Got to say r11392 is a good improve on speed. Going through settings is as fast as in my netbook.
Keep up the good work. :)
b0x
Sun Jun 24, 2012 4:57 pm
So far... enjoying having menu sounds again.
System stayed up all night. Had turned off the slideshow screen saver which seems to be an issue last few builds. Like it can't find the next fan art and just sticks on the current one bouncing around the screen, but if you try wake up the system it just hangs.
Tried for the first time to actually play an mp3 with 11392 (can't believe I haven't before this). Well doesn't work - here's the log ERROR: CAudioDecoder: Unable to Init Codec while loading file /storage/Site/Music/.............mp3
I pull from a mounted nfs and an smb share as well. Tried pulling from both separately. Will also copy over an mp3 to the sd card and see if that works later.
wido
Sun Jun 24, 2012 10:49 pm
I have problems with viewing most photos with openelec. I tried several home compilations and the latest development build provided on openelec.tv. I haven't found out what is similar in the pictures that give problems. It might have to do something with size (in MB's) because pics made from an old phone gave no problems.
This is what xbmc.log says:
22:36:18 T:1235555424   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
22:36:29 T:1157379168   ERROR: Previous line repeats 1 times.
22:36:29 T:1157379168   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
22:36:30 T:1235555424   ERROR: Previous line repeats 50 times.
22:36:30 T:1235555424   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
22:36:30 T:1157379168   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
22:36:35 T:1235555424   ERROR: Previous line repeats 51 times.
22:36:35 T:1235555424   ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.image_decode wait event timeout
When this happens, SSH still works but the screen freezes and it does not react to any remote control (MCE) buttons anymore.
onetootreefor
Sun Jun 24, 2012 10:55 pm
well menu sounds work great! it sounds great, but like some others im hearing some faint white noise while on the menus, doesnt have the white noise when it switches to video playback, but just while the menus are up. Thanks for your efforts!
milhouse
Sun Jun 24, 2012 11:32 pm
Just rescanning my db with rvn11392 to verify the "orientation" fix, but before initiating the scan I did notice (while browsing Videos -> Files) the presence of "blank" cover art which appears in the logs as follows (the example is for the "folder.jpg" image associated with the Star Trek set directory - this image failed to appear when browsing the NFS directory in Videos->Files, but exiting then re-entering Videos->Files confirmed it was converted, but not displayed the first time):
00:15:48 T:1291629664   DEBUG: DllSwScale: Using libswscale system library
00:15:48 T:1208046688   DEBUG: CNFSFile::Open - opened /mnt/share/media/Video/Movies/Star Trek/folder.jpg
00:15:48 T:1312523360   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_encode input port 340 output port 341
00:15:48 T:1312523360   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_encode) - port(340), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(896000), nBufferAlignmen(16)
00:15:48 T:1312523360   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.image_encode) - port(341), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(224000) nBufferAlignmen(16)
00:15:49 T:1208046688   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
00:15:49 T:1208046688   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
00:15:49 T:1208046688   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
00:15:49 T:1312523360   DEBUG: COMXImage::CreateThumbnailFromSurface : special://masterprofile/Thumbnails/1/14517932.jpg width 392 height 560
00:15:49 T:1208046688   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(5999616) nBufferAlignmen(16)
00:15:49 T:1208046688   ERROR: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - OMX_UseBuffer failed with omx_err(0x80001000)
00:15:49 T:1208046688   ERROR: COMXImage::Decode m_omx_resize.AllocOutputBuffers result(0x80001000)
00:15:49 T:1278821472   DEBUG: CNFSFile::Close closing file /mnt/share/media/Video/Movies HD/Spider-Man Collection/folder.jpg
00:15:49 T:1278821472   DEBUG: Caching image 'nfs://192.168.0.3//mnt/share/media/Video/Movies HD/Spider-Man Collection/folder.jpg' at 995x560 with orientation 0 as '6/60cd2647.jpg'
00:15:49 T:1278821472   DEBUG: DllSwScale: Using libswscale system library
00:15:49 T:1208046688   ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.image_decode wait event 0x00000000 timeout 300
00:15:49 T:1208046688   ERROR: COMXCoreComponent::SetStateForComponent - OMX.broadcom.resize failed with omx_err(0x80001000)
00:15:49 T:1208046688   DEBUG: CNFSFile::Close closing file /mnt/share/media/Video/Movies/Star Trek/folder.jpg
00:15:49 T:1208046688   DEBUG: CNFSFile::Open - opened /mnt/share/media/Video/Movies/Star Trek/folder.jpg
00:15:49 T:1312523360   DEBUG: CNFSFile::Open - opened /mnt/share/media/Video/Movies HD/Star Wars Collection/folder.jpg
00:15:50 T:1312523360   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
00:15:50 T:1312523360   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
00:15:50 T:1312523360   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
00:15:50 T:1312523360   DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(5990400) nBufferAlignmen(16)
00:15:50 T:1208046688   DEBUG: CNFSFile::Close closing file /mnt/share/media/Video/Movies/Star Trek/folder.jpg
00:15:50 T:1157297248   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.resize - OMX_ErrorInsufficientResources, insufficient resources
00:15:51 T:1312523360   ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.image_decode wait event 0x00000004 timeout 1000
00:15:51 T:1312523360   ERROR: COMXImage::Decode m_omx_decoder.WaitForEvent result(0x7fffffff)
00:15:51 T:1278821472   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
00:15:51 T:1278821472   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
00:15:51 T:1291629664   ERROR: COMXCoreComponent::Initialize - could not get component handle for OMX.broadcom.image_encode omx_err(0x80001000)
00:15:51 T:1291629664   ERROR: COMXImage::Encode error m_omx_encoder.Initialize
00:15:51 T:1312523360   DEBUG: CNFSFile::Close closing file /mnt/share/media/Video/Movies HD/Star Wars Collection/folder.jpg
00:15:51 T:1312523360   DEBUG: CNFSFile::Open - opened /mnt/share/media/Video/Movies HD/Star Wars Collection/folder.jpg
00:15:52 T:1208046688   DEBUG: Caching image 'nfs://192.168.0.3//mnt/share/media/Video/Movies/Star Trek/folder.jpg' at 995x560 with orientation 0 as 'f/fc2bb605.jpg'
What seems to happen is that after a fresh boot (and having previously deleted Textures13.db and Thumbnails folder), as you scroll through the list of available files/folders in Videos->Files, initially all appears well but then having scrolled through 6 or 7 pages of Thumbnails (Thumbnail view) "blank" thumbnail images begin to appear, and as you continue to scroll through the list, these blank images appear with increasing frequency suggesting that whatever the problem is, it's getting worse. Eventually, the entire GUI can become unstable, as it is no longer able to load images.
milhouse
Sun Jun 24, 2012 11:34 pm
rvn11392: Confirming there are no menu sounds (or mp3 audio) being output over analog (3.5mm headphone).
CocodaMonkey
Mon Jun 25, 2012 12:39 am
Lightning303 wrote:Also tried playing back my testing video which worked on old versions, couldnt start it at all. It says "Working..." for a while and then freezes (1080p h264).
Did you try more than once? I've had this exact issue in all versions so far. It never actually freezes unless I try to stop it though. Sometimes is just says working and never loads the video. I can reset the Pi and try the same video again and it'll work though.
b0x
Mon Jun 25, 2012 4:55 am
another note-
on all versions I've tried so far, the web based remote turns down the volume, but not up. volume pops up on the screen but no matter how many times I click the plus symbol it does nothing to change the volume level to louder.
Nodge
Mon Jun 25, 2012 1:03 pm
Tried R11394 but still having problems with TV Series banners. In fact it seems to be 1 step forward and 2 back. After scraping the TV Database the artwork for "recently uploaded" episodes which appear above the "TV Series" in the main menu all appear ok and unscrambled. But if I actually select "TV Series" and get a list of the tv series then only 3 or 4 out of 13 have banners against them. Previously they were all there but some got scrambled if viewed more than once. If I go through the various views then it eventually locks up. With R11392 I found that if I rebooted then another 2 or 3 banners would appear but not all of them. The worst thing is that on both builds I couldn't play any of the files I selected. Just got the "Working" message with nothing happening and then when I select "Stop" it all locks up again.
Return to “Media centres”
