No obvious problems with mp4 media, but NFS is pretty flaky in OpenELEC - has been since XBMC updated to a new version of libnfs - and I'm lucky if NFS works one boot out of three.gdekoning wrote:Loving OpenElec on the RPi!
Just wanted to note that .mp4 files do not play for me on the latest test build (OpenELEC-RPi.arm-devel-20120623232506-r11392) whereas they do work on Raspbmc. When I try to load one it just keeps loading, but nothing happens and I eventually have to turn my Pi on and off.
I am trying to play the files over a NFS connection.
edit:
Just updated to OpenELEC-RPi.arm-devel-20120628211407-r11437 and still no luck :/
Anyone else have the same problem?
Re: OpenELEC Testbuilds
That sucks :/ I could not even connect with NFS under Raspbmc, but tried to do the following (as posted on the forums at Raspbmc link and it seems you tried this yourself on Raspbmc! as I see your username in the thread - unless its a different milhousemilhouse wrote: No obvious problems with mp4 media, but NFS is pretty flaky in OpenELEC - has been since XBMC updated to a new version of libnfs - and I'm lucky if NFS works one boot out of three.
sudo su
cd /tmp
wget http://db.tt/uREQJ9vu -O libnfs.so.1.0.3
rm /usr/lib/libnfs*
mv libnfs.so.1.0.3 /usr/lib
cd /usr/lib
ln -sf libnfs.so.1.0.3 libnfs.so.0
ln -sf libnfs.so.1.0.3 libnfs.so.1
ln -sf libnfs.so.1 libnfs.so
sync
reboot
Same.gdekoning wrote:unless its a different milhouse
The problem with OpenELEC is that replacing system components is not as easy as it is in Raspbmc, so no I don't think it will work - you'll need an OpenELEC image that is built with the updated libnfs library.gdekoning wrote:You think the same might work for you with OpenElec?
Thanks! I will give it a gohumla wrote: Since the introduction of alsa in r11392, video playback has been hampered, it should be fixed soon, but reverting to r11315 should give smooth playback(although no menu sounds).
Ah I see, thats a shame :/ Out of curiosity; what are you using now as a streaming protocol? I am currently running Windows Vista and using "haneWIN NFS Server" to stream video to my Pi but was wondering if there are any better protocols that can be used under Windows Vista.milhouse wrote: The problem with OpenELEC is that replacing system components is not as easy as it is in Raspbmc, so no I don't think it will work - you'll need an OpenELEC image that is built with the updated libnfs library.
- Raspberry Pi Engineer & Forum Moderator
I use haneWIN NFS server on Windows 7, and I'm not aware of anything better for Windows.gdekoning wrote: Ah I see, thats a shame :/ Out of curiosity; what are you using now as a streaming protocol? I am currently running Windows Vista and using "haneWIN NFS Server" to stream video to my Pi but was wondering if there are any better protocols that can be used under Windows Vista.
I still use NFS exported from a FreeNAS 8.0.2 NAS, for both Raspbmc and OpenELEC. Even though NFS is flaky in OpenELEC I'm confident it will get fixed eventually (though sooner than later would be nice!gdekoning wrote: Ah I see, thats a shame :/ Out of curiosity; what are you using now as a streaming protocol? I am currently running Windows Vista and using "haneWIN NFS Server" to stream video to my Pi but was wondering if there are any better protocols that can be used under Windows Vista.
NFS is certainly better (less overhead) than CIFS/SMB (the default Windows sharing protocol), it's possible that FTP might be more efficient still than NFS - never tried it myself though.
I tried using FTP as a streaming protocol but this was a nightmare for me, but it might work for others. I am getting far better results with NFS.milhouse wrote: NFS is certainly better (less overhead) than CIFS/SMB (the default Windows sharing protocol), it's possible that FTP might be more efficient still than NFS - never tried it myself though.
How to setup wireless on tthis build?
I have dwa-121 dlink adapter which is rtl8192cu chipset. It works under normal debian build.
Is it possible to set it up under OpenELEC_
Thanks,
Thanks,
currently openelec does not support this chipsetkomple wrote:How to setup wireless on tthis build?
Thanks,
been using FTP from the start and its completely reliable and hasnt given any problem.gdekoning wrote:I tried using FTP as a streaming protocol but this was a nightmare for me, but it might work for others. I am getting far better results with NFS.milhouse wrote: NFS is certainly better (less overhead) than CIFS/SMB (the default Windows sharing protocol), it's possible that FTP might be more efficient still than NFS - never tried it myself though.
good thing with ftp is that it is ancient and basic and that makes it efficient and doesnt get compatibility issues.
Lightning303 wrote:currently openelec does not support this chipsetkomple wrote:How to setup wireless on tthis build?
Thanks,, i am waiting too. there is however an open issue on github for this, so i guess in the future they will add the drivers. https://github.com/OpenELEC/OpenELEC.tv/issues/601
Thanks for these easy to read changelogs as there's many of us nubs out here.sraue wrote:Hi,
Another short update (r11392):
Not sure if it's a fixable issue but I've had problems with very old Divx files with a codec id of Div3Low giving a black screen with sound. A lost cause?
openelec is working well for me but during video playback I have black bars top and bottom of the screen. I have tried
!: Video calibration
2: resolution changes
3: config.txt ( disable_overscan=1 and also top and bottom overscan changes and hdmi changes)
4:Driver settings.
5: Different hdmi TV's (one 1080 and the other 720)
6:Also tried rapbmc
But nothing seems to work anyone have any ideas.
4:Driver settings.
6:Also tried rapbmc
So what do you mean by black bars, the video is squashed between BB, the video is cropped by the BB? The only time I had an issue like this was when the video calibration was broken for the menu and on reboot I'd have a black border overlay all the way around the screen so the video would be cropped. This was fixed with the latest patches to xbmc from gimli which openelec now includes.Vermillion wrote:openelec is working well for me but during video playback I have black bars top and bottom of the screen. I have tried
4:Driver settings.
6:Also tried rapbmc
Rob
squashed between BB. and all the builds I have tried produce the same results. I am presently on a build from yesterday.welshblob wrote:So what do you mean by black bars, the video is squashed between BB, the video is cropped by the BB? The only time I had an issue like this was when the video calibration was broken for the menu and on reboot I'd have a black border overlay all the way around the screen so the video would be cropped. This was fixed with the latest patches to xbmc from gimli which openelec now includes.Vermillion wrote:openelec is working well for me but during video playback I have black bars top and bottom of the screen. I have tried
4:Driver settings.
6:Also tried rapbmc
Rob
I think he's refering to the forced letterboxing on these builds! No matter what "View Mode" you sellect in video options the video olways remains letterboxed!
In my PC running Eden, when you change the view mode to 16:9 it stretches the picture to fullscreen, but on these Pi builds it doesnt..
I have yet to find a Pi build of OpenELEC which is able to stretch 4:3 content so that it fills a 16:9 screen. This is a very common feature in other media setups. OpenELEC on Pi seems to have an option for it but it does nothing at all.
I managed to get 8192cu working.Lightning303 wrote:currently openelec does not support this chipsetkomple wrote:How to setup wireless on tthis build?
I have Edimax EW-7811Un which is also using 8192cu driver.
Here's how I did it:
- Build openELEC
- Download driver from http://nathan.chantrell.net/downloads/r ... 715.tar.gz (googled somewhere)
- Cross compile the driver using toolchain from openELEC, using this script:
Don't forget to replace path_to with correct paths.
PATH=/path_to_openELEC/build.OpenELEC-RPi.arm-devel/toolchain/bin:$PATH CFLAGS += -march=armv6zk -mcpu=arm1176jzf-s -mabi=aapcs-linux -Wno-psabi -Wa,-mno-warn-deprecated -mfloat-abi=hard -mfpu=vfp -fomit-frame-pointer -Wall -pipe -O3 -fexcess-precision=fast -ffast-math -I/path_to_openELEC/build.OpenELEC-RPi.arm-devel/toolchain/armv6zk-openelec-linux-gnueabi/sysroot/usr/include/libnl3/ make ARCH=arm CROSS_COMPILE=armv6zk-openelec-linux-gnueabi- -C /path_to_openELEC/build.OpenELEC-RPi.arm-devel/linux-3.2.21 M=/path_to_unpacked_driver/rtl8192_8188CU_linux_v3.0.2164.20110715 modules
- Now we need to blacklist the original rtl8192 driver, upload our freshly built one, and run depmod -a. Unfortunately the root filesystem is squashfs (read-only), so it's needed to unsqash it, modify and repack it again.
# mount the squashfs (SYSTEM file) mkdir /tmp/squashy sudo mount -o loop SYSTEM /tmp/squashy # copy the whole filesystem to new location mkdir /tmp/newsquashy sudo -i find /tmp/squashy -xdev -print0 | cpio -pd0V /tmp/newsquashy # remove the old drivers rm -rf /tmp/nwesquashy/lib/modules/3.2.21/kernel/drivers/net/wireless/rtlwifi/ # copy our module cp /path_to_unpacked_driver/rtl8192_8188CU_linux_v3.0.2164.20110715/8192cu.ko /tmp/newsquashy/lib/modules/3.2.21/kernel/drivers/net/wireless # run openELEC's toolchain depmod /path_to_openELEC/build.OpenELEC-RPi.arm-devel/toolchain/bin/depmod -b /tmp/newsquashy/ 3.2.21 # build the new squashfs image mksquashfs /tmp/newsquashy/ SYSTEM
- Copy the SYSTEM file to the sdcard.
I suspect there will be some incopatibility problem between wpa_supplicant and the driver because i see some ioctl operation not permitted errors...
Would it be possible to decrease te size of the 2gb image?
Doesn't want to write to a 2gb toshiba sd card cuz it comes a few bytes short.
If images are made from actual SD cards then this can too easily happen (unless you happen to have a card that's at the small end of the stated size). That's why I make images onto a small virtual hard disk, and modify the create script to leave a few spare blocks at the end. My build bot spits out images and release bundles here (latest is r11468 - it's been brought to my attention that the zip files don't open properly using Windows, so use 7zip or similar or wait for the next drop, which should fix it).Terranigma wrote:Would it be possible to decrease te size of the 2gb image?
Thanks for clearing that up, So at least I know there is nothing more I can do to achieve full screen.keenan wrote:I think he's refering to the forced letterboxing on these builds! No matter what "View Mode" you sellect in video options the video olways remains letterboxed!
It must have something to do with a forced aspect ratio! Some videos, like downloaded series episodes do actualy fill the screen, but if something is encoded using a wider or narrower AR for that matter it simply does'nt alter it. That's why all 4:3 AR videos stay the same aswell...
- sparky0815
- Contact: Website
build r11487:
you can download unofficial sdcard images (2GB and 4GB) on
http://sparky0815.de/openelec-download- ... fat-files/
have fun
greetings
have fun
greetings
Twitter: @Sparky0815
Facebook Gruppe (RaspberryPi - Deutschland): http://on.fb.me/PnYE99
Trying out r11493.
Anyone else having issues with only 3-5 fan art images loading then the rest refusing to load? Once they stop loading, leaving the TV Shows menu causes XBMC to hang and I have to kill it from ssh. I am getting a lot of this in my xbmc.log.
19:30:31 T:1189065824 WARNING: COMXImage::Decode progressive images not support
com.image_decode - OMX_EventError detected, nData1(0x80001005), port 0
20:00:39 T:1230255200 ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.ima
ge_decode wait event 0x00000003 timeout 300
20:00:39 T:1157174368 ERROR: COMXCoreComponent::DecoderEventHandler OMX.broad
com.image_decode - OMX_ErrorStreamCorrupt, Bitstream corrupt
20:00:40 T:1230255200 ERROR: COMXCoreComponent::GetInputBuffer OMX.broadcom.i
mage_decode wait event timeout
20:01:16 T:1103310848 WARNING: GetIcon - Unknown nodetype requested videodb://2
/2/3/1/
/2/3/2/
/2/3/3/
/2/3/4/
/2/3/5/
/2/3/-1/
