I have set up an XBMC media center on my RPi, running on RaspBMC. In addition I've set up another one on another TV, where the first one acts as a server with all the files for the other one. I've linked the libraries via UPnP and it is working great, but not with 720p or higher HD media. I guess the problem is slow transfer speed, as I noticed it when transferring files to my media discs.
On both FTP and SMB transfer speed is between 300 and 1000 kB/sec, usually 500 kB/sec. Both my PC and RPi are connected through WiFi, via a good router, so I believe this should not be a problem. Where could the bottleneck of these transfers? RPi's CPU? WiFi? RaspBMC's settings?
On a side note: when I'm transferring files from my Ubuntu 12.04 to my RaspBMC via FTP, I get "host connection closed" error after some 10 minutes or so. Why?
Thank you for your help
