Still having issues with my thumb drive. I realized it wasn't mounting correctly or mounting after a reboot. I followed this guide, http://www.raspberrypi-spy.co.uk/2014/0 ... pberry-pi/ substituting root for pi as the user but I am getting the following error: mount: unknown filesystem type 'gid=root'.
This is my fstab file:
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mmcblk0p2 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, so no using swapon|off from here on, use dphys-swapfile swap[on|off] for that
# This part of the file describes how your external HDs or network shares are connected to SqueezePlug
# You should follow this structure:
# every external HD or network share should be mounted under /mnt
# then use "hd1" for the first HD and so on
# NFS shares should be mounted on /mnt/nfs
# Samba shares should be mounted on /mnt/samba
# the rest of the structure is build on the external HD or network share itself, you can arrange this by yourself or by the library script from $
# Common structure:
# /mnt/hd1/backup
# /mnt/hd1/data
# /mnt/hd1/itunes
# /mnt/hd1/media
# /mnt/hd1/media/audio
# /mnt/hd1/media/pictures
# /mnt/hd1/media/playlists
# /mnt/hd1/media/video
# /mnt/hd1/media/misc
# /mnt/hd2/...
# /mnt/hdx/...
# /mnt/nfs/...
# /mnt/samba/...
# Your manual setting should start here:
# For USB Fat/Fat32/Ext2/Ext3/Ext4 drives edit the next line e.g.:
3/dev/sdx /mnt/hd1 auto rw,user,auto 0 0
# For USB NTFS drives edit the next line e.g.:
# /dev/sdx //mnt/hd1 ntfs-3g defaults,locale=en_US.utf8 0 0
# For NFS shares edit the next line e.g.:
# 192.168.2.100:/raid/data/iTunes_music /mnt/nfs nfs defaults 0 0
# For Samba Client shares edit the next line e.g.:
# //192.168.2.10/samba /mnt/samba/ cifs username=<username>,password=<password>
# Automatic settings from SqueezePlug scripts starts here:
UUID=1614-4446 /media/usb auto,users,rw,uid=root,gid=root 0 0
Any suggestions?
Re: SqueezePlug Version 7 available
Is that on a Pi?twiddlepie wrote:I'm using squeezelite
Looks like you've got a mix of manual and auto settings, eg. above:anjenaire wrote:Still having issues with my thumb drive. I realized it wasn't mounting correctly or mounting after a reboot. I followed this guide, http://www.raspberrypi-spy.co.uk/2014/0 ... pberry-pi/ substituting root for pi as the user but I am getting the following error: mount: unknown filesystem type 'gid=root'.
# Common structure:
# /mnt/hd1/backup
# /mnt/hd1/data
# /mnt/hd1/itunes
# /mnt/hd1/media
# /mnt/hd2/...
# /mnt/hdx/...
# /mnt/nfs/...
# /mnt/samba/...
Any suggestions?
and
Not sure what the 3 is doing there ???
Yes, its on a picastalla wrote:Is that on a Pi?twiddlepie wrote:I'm using squeezelite
A long shot: at terminaltwiddlepie wrote:Yes, its on a picastalla wrote:Is that on a Pi?twiddlepie wrote:I'm using squeezelite
sudo apt-get install mpg123
Reboot and try kiwi fm again.
Reboot and try kiwi fm again.[/quote]
Tried that, but unfortunately it didn't seem to help. Any other suggestions? Is there a log that might indicate the problem?
Tried that, but unfortunately it didn't seem to help. Any other suggestions? Is there a log that might indicate the problem?[/quote]twiddlepie wrote:A long shot: at terminal
Okay - might be a LMS issue.
At LMS gui
Settings
Advanced
Select File type from top left drop down menu
Check MP3 is set to Native
Okay - might be a LMS issue.castalla wrote:Tried that, but unfortunately it didn't seem to help. Any other suggestions? Is there a log that might indicate the problem?twiddlepie wrote:A long shot: at terminal
At LMS gui
Settings
Advanced
Check MP3 is set to Native[/quote]
So under file format "MP3", it is set to "native". However, for all the other file formats, ie AAC, MP3 is set to disabled. could that be an issue?
twiddlepie wrote:Okay - might be a LMS issue.castalla wrote:Tried that, but unfortunately it didn't seem to help. Any other suggestions? Is there a log that might indicate the problem?twiddlepie wrote:A long shot: at terminal
At LMS gui
Settings
Advanced
So under file format "MP3", it is set to "native". However, for all the other file formats, ie AAC, MP3 is set to disabled. could that be an issue?[/quote]
No
I'm at a loss, I'm afraid.
Have you done a firmware update on the Pi ? In squeezeplug setup - one of the options.
yeah, i did the firmware update as part of the installation. But I have a wolfson audio card, and it says not to do any further firmware updates after that. can i still do it without affecting the audio card set up?
Oh-oh - now you tell me! No idea. Guess it's a card issue .... can't help on that. Suggest you post on the slimdevices forum.twiddlepie wrote:yeah, i did the firmware update as part of the installation. But I have a wolfson audio card, and it says not to do any further firmware updates after that. can i still do it without affecting the audio card set up?
confusingly it happily plays MP3 music files off my NAS drive...
Thanks for the suggestions!
Ah, the three was the result of a tired pinky on the shift key and should have been a # sign. Fixed that, deleted the last line. And then tried apt-get usbmount. Going through another database refresh on the LMS server. I think I can mount the device o.k. it is the automount that is a little tricky for me. Anyway, currently, the thumbdrive is located at usb0 (even though I had previously designated it usb) so I will see if it works going forward and if after moving the pi to its operating place on my equipment rack, I can get it to see the thumb drive in the same location.castalla wrote: Looks like you've got a mix of manual and auto settings, eg. above:
and
Check LMS gui - Players - drop down Audio - MP3 Streaming - usually set to Direct but you could try Proxied ....twiddlepie wrote:confusingly it happily plays MP3 music files off my NAS drive...
Still having issues after coming home tonight. The music seems to have an issue buffering. It plays for just a few seconds and then quits. It's like it fills up and then can't continue. Here's my scan report:anjenaire wrote:Ah, the three was the result of a tired pinky on the shift key and should have been a # sign. Fixed that, deleted the last line. And then tried apt-get usbmount. Going through another database refresh on the LMS server. I think I can mount the device o.k. it is the automount that is a little tricky for me. Anyway, currently, the thumbdrive is located at usb0 (even though I had previously designated it usb) so I will see if it works going forward and if after moving the pi to its operating place on my equipment rack, I can get it to see the thumb drive in the same location.castalla wrote: Looks like you've got a mix of manual and auto settings, eg. above:
and
Logitech Media Server Status
Logitech Media Server Version: 7.8.1 - 1417096620 @ Fri Nov 28 03:04:26 UTC 2014
Hostname: squeezeplug
Server IP Address: 192.168.0.93
Server HTTP Port Number: 9000
Operating system: Debian - EN - utf8
Platform Architecture: armv7l-linux
Perl Version: 5.14.2 - arm-linux-gnueabihf-thread-multi-64int
Database Version: DBD::SQLite 1.34_01 (sqlite 3.7.7.1)
Total Players Recognized: 1
Library Statistics
Total Images: 596
Total Videos: 0
Total Tracks: 3,301
Total Albums: 264
Total Artists: 165
Total Genres: 52
Total Playing Time: 225:56:53
Media Scan Details
Discovering playlists: /media/usb0 (566 of 566) Complete 00:00:40
Scanning new playlists: /media/usb0 (239 of 239) Complete 00:02:32
Find updated coverart files (260 of 260) Complete 00:00:02
Media scan terminated unexpectedly (Scanning Progress)
Total Time: 00:03:14 (Sunday, November 30, 2014 / 8:37 PM)
Player Information
Information on all identified devices connected to Logitech Media Server
Basement
Player Model: SqueezeLite
Player IP Address: 192.168.0.142
Player MAC Address: b8:27:eb:05:cb:05
Folders
Cache Folder
/var/lib/squeezeboxserver/cache
Preferences Folder
/var/lib/squeezeboxserver/prefs
Plugin Folders
/var/lib/squeezeboxserver/cache/InstalledPlugins/Plugins, /usr/sbin/Plugins, /usr/share/squeezeboxserver/Plugins
Logitech Media Server Log File
/var/log/squeezeboxserver/server.log (100, 500, 1000 lines)
Scanner Log File
/var/log/squeezeboxserver/scanner.log (100, 500, 1000 lines)
This is just frustrating. I think I should be able to play the music off the thumb drive connected directly to the rpi. It's only acting as a server with the music playing on a separate rpi. All Flac files and the thumb drive was formatted a FAT from the get go.
Hi, I tried this, but it didnt make a difference. However I notice on the GUI under "Bitrate Limiting", it says "No Limit" and then underneath that:castalla wrote:Check LMS gui - Players - drop down Audio - MP3 Streaming - usually set to Direct but you could try Proxied ....twiddlepie wrote:confusingly it happily plays MP3 music files off my NAS drive...
"(Note: You do not appear to have LAME installed. Logitech Media Server will need the LAME MP3 encoder installed on your system to do conversion to MP3. You can find out more about LAME here.) "
Do I need LAME installed? Could that be the problem?
twiddlepie wrote:Hi, I tried this, but it didnt make a difference. However I notice on the GUI under "Bitrate Limiting", it says "No Limit" and then underneath that:castalla wrote:Check LMS gui - Players - drop down Audio - MP3 Streaming - usually set to Direct but you could try Proxied ....twiddlepie wrote:confusingly it happily plays MP3 music files off my NAS drive...
No. I just tried squeezelite on a Pi with Kiwi fm - played okay.
I have one more idea to try but before that, check the
post on slimdevices .... earlier
HI all,
I have tried numerous times to download the image for Squeezeplug from www.squeezeplug.de and it keeps dropping the download after about 10MB of the download. Is it available at another host, such as Github or Sourceforge?
Hey,
I cant seem to post a reply on slim devices forum... anyway, I can see mp3 listed when i run squeezelite -h in the -c line. It says
-c <codec1>, <codec2> Restrict codecs to those specified, otherwise load all available codecs; known codecs: flaac,pcm,mp3,ogg,aac,dsd (mad,mpg for specific mp3 codec)
Isn't this just a list of what COULD be there, rather than what IS there?
Anyway, if i run
"sudo apt-get install libmad
then
sudo apt-get install libmpg12"
It says:
"E: Unable to locate package libmad"
and " E: Unable to locate package libmpg123"
is that what you expected?
Anyway, if i run
then
It says:
Blast!twiddlepie wrote:Hey,
Anyway, if i run
then
It says:
I'm getting lost over this.
Can you confirm that it's all mp3 stations?
I wonder if it could be a bit-rate issue?
Try
sudo apt-get install libmad0
that's a zero
Beyond that I've run out of ideas - other than to reinstall without the dac and check whether you get the same problem.
Hey,castalla wrote:Blast!twiddlepie wrote:Hey,
Anyway, if i run
then
It says:
Try
that's a zero
So i tried that, but it said the latest version of libmad was already installed.
As far as I can tell, it's all mp3 radio stations i have tried, but i only really notice when a station doesn't play, and all the ones that dont play are mp3.
I uninstalled sequeezelite and re installed it without the wolfson audio card, and now i can play mp3 radio stations strait off the Pi line out, so it is obviously something with the sound card.
Does anyone here know anything about the wolfson audio card and why it wont play mp3 radio stations?
Cheers, Adrian
Have you reinstalled the card and tried again?
IckStream
Anybody tried the new ickStream yet?
Not sure what extra features it brings, would be interested to hear if anybody has experience.
http://wiki.ickstream.com/index.php/Ope ... Squeezebox
I uninstalled Squeezelite and when I re installed it and added the Wolfson, it said "looks like wolfson is already installed" or something like that. Do you know how i can uninstall the wolfson stuff without starting from scratch with the LMS as well? I have loaded some accounts, i.e. Slacker, and i have misplaced my password, so don't want to re-load that, if I can help it...castalla wrote:Have you reinstalled the card and tried again?
OK, so i just went through the whole install again through squeezeplug (LMS & Squeeezelite), and no luck with the mp3 radio again, unfortunately.twiddlepie wrote:I uninstalled Squeezelite and when I re installed it and added the Wolfson, it said "looks like wolfson is already installed" or something like that. Do you know how i can uninstall the wolfson stuff without starting from scratch with the LMS as well? I have loaded some accounts, i.e. Slacker, and i have misplaced my password, so don't want to re-load that, if I can help it...castalla wrote:Have you reinstalled the card and tried again?
is there anyone else that is using a wolfson audio card?
