Page 14 of 19
Re: SqueezePlug Version 7 available
Posted: Sun Aug 03, 2014 1:01 pm
by aftours
six3323 wrote:Hi together,
i am new with my raspberry and started with the squeezebplug. Installation and setup with squeezelite works fine - GREAT !!!!
My Raspberry should work as a squeezebox client ... and i would like to connect a TFT to the hdmi an see the Squeezebox Menu with CD Cover etc. (like the original squeezebox touch).
I could not find any tipps or howtos ... for my wish. My Raspberry boots to the squeezeplug login and ich can't find any option in setup to change this.
Pleas help me with a noobie tutorial (i have linux knowledge).
This image is for headless use, so you do not have to use a monitor. You can acces a "what is playing now" monitor by using the webinterface or downloading an app for your phone or tablet.
I understand your wish, but i think it is not possible with the standalone image and no linux skills. Also the raspberry pi is not the most powerfull device for running a server, client and a monitor.
Posted: Sun Aug 03, 2014 6:50 pm
by six3323
Thanks for your answer.
I thought this is possible with squeezeplug ... i think i read something about jivelite which should be incl. in squeezeplug but i could find more detailted informations about it.
Is there any image (out of the box) which has a grafik menu ... or which does what i want ... or is the Raspberry not powerfull enough for that?
Posted: Sun Aug 03, 2014 7:21 pm
by drgeoff
six3323 wrote:Thanks for your answer.
http://www.instructables.com/id/Wall-Mo ... -Pi/#step0
Posted: Sun Aug 10, 2014 4:07 pm
by plakjekaas
I have a Raspberry b+. Can not get Squeezeplug to work on it.
It shuts down all USB ports at the end of the boot sequence, and is not getting an IP address.
During the boot sequence I can abort the booting by pressing ^C on the keyboard so it does work, I also can use the attached USB keyboard, but letting the boot finish will shut down the keyboard too so I am not able to login into the Raspberry to check out.
Tried different SD cards and power supplies but all same with the same result.
Raspbmc and Openelec run fine btw, including network and usage of the keyboard.
Any ideas ?
thank you
Posted: Sun Aug 10, 2014 5:28 pm
by drgeoff
plakjekaas wrote:Hi,
Any ideas ?
thank you
100% sure this is because the firmware in Squeezeplug is too old. Search the forum for how to update it. (In essence you need to get bootcode.bin and start.elf versions dated July 2014 or later.)
http://www.raspberrypi.org/forums/viewt ... 63&t=83590
Posted: Mon Aug 11, 2014 7:58 am
by castalla
Any ideas ?
thank you
Are bootcode.bin and start.elf sufficient?
Posted: Mon Aug 11, 2014 8:54 am
by drgeoff
castalla wrote: Are bootcode.bin and start.elf sufficient?
I believe so. http://www.raspberrypi.org/forums/viewt ... 5&p=586428. AndrewS in that thread is the author of NOOBS.
Are you having a problem yourself or querying on behalf of plakjekaas?
Posted: Mon Aug 11, 2014 10:13 am
by castalla
Just a clarification. There's been similar queries on the slimdevices forum.
Posted: Mon Aug 11, 2014 3:56 pm
by plakjekaas
Any ideas ?
thank you
It was indeed the case of old "firmware".
You actually need to replace all the files (only bootcode.bin and start.elf is not sufficient) with the latest to be found on github (see below).
Works like a charm now.
Just download the files and copy them on the SD.
https://github.com/raspberrypi/firmware ... aster/boot
Thanks for the pointer, solved some other issues along the way too :-)
Posted: Thu Aug 14, 2014 11:04 pm
by aftours
Any ideas ?
thank you
A simple firmware update in den squeezeplug setup solved the problem for me. It is in the "advanced configuration" menu, where you also have the chance to backup your currently using firmware, just in case you know ;-)
But for this you need a Raspberry B with a working internetconnection and then you are free to use your b+ ;-)
Posted: Mon Aug 18, 2014 7:42 pm
by fuzzweed
Hi, is there a log file or something generated by squeeze plug. My RPi keeps disappearing from the network so I'm guessing its crashing. (or could be a wireless issue?) but I don't know where to start to trace the issue. Thanks. Jim
Posted: Tue Aug 19, 2014 8:24 am
by aftours
My LMS Server kept disappearing in the network too. I decided to run the lms server on my HP microserver N54L which is a big improvement compared to the raspberry pi. The raspberry pi works now as a player only which is way more stable!
Posted: Tue Aug 19, 2014 6:14 pm
by Paul Webster
I have finally got around to writing up how I set-up a couple of my RPi systems to allow controlling of the player via infra-red remote.
While not something that is necessary, there are occasions, like when the phone rings and you need to pause things, that using a phone-based app or firing up a web browser is too slow.
I have it working with a Creative USB DAC (where the infra-red controls get intercepted by the device and passed through USB) and the IQaudIO DAC add-on board where I added a cheap infra-red receiver and used a regular domestic DVD player remote control.
http://dabdig.blogspot.com/2014/08/infr ... n-rpi.html
Edit: is there a BBCode for this forum to change the size of the displayed image (rather than me having to create a new small version and upload it somewhere)?
Posted: Tue Aug 19, 2014 7:41 pm
by fuzzweed
I'm only using it as a player, but it's not that reliable so far. Just would like a log file I can browse through to see where the cause is...
Posted: Tue Aug 19, 2014 8:45 pm
by Paul Webster
Which application are you using as your player?
Posted: Wed Aug 20, 2014 5:55 am
by fuzzweed
squeezelite
Posted: Wed Aug 20, 2014 3:16 pm
by Paul Webster
In that case you can add the "-d" parameter to the command line for it.
Note it takes parameters - https://code.google.com/p/squeezelite/
You will then get a log that you can review.
I presume that it is not on by default to help reduce the chance of the SDCard (in the case of RPi) filling up or wearing out.
Posted: Sat Aug 23, 2014 6:33 pm
by fuzzweed
Thanks for the info. Will look further into the problem when I get a moment!
Posted: Sat Sep 13, 2014 9:04 am
by fuzzweed
So the problem appears to be with the wireless connection. For some reason it drops connection randomly and won't re-establish.
I'm using one of these.
http://www.amazon.co.uk/The-Pi-Hut-Adap ... B009FA2UYK
I have relocated the Rpi to different areas of the house and tried different routers, but the same problem occurs so I have to presume the problem lies with the Rpi or USB dongle.
Any thoughts on a cause, or suggestions for a different (tested) wireless dongle.
Posted: Sat Sep 13, 2014 9:45 am
by DougieLawson
What WiFi dongle are you using? Have you disabled power saving for it?
Posted: Sat Sep 13, 2014 10:21 am
by fuzzweed
Dongle as per link in post above. How / where do I disable power saving? - this sounds like a sensible thing to investigate.
Posted: Sun Sep 14, 2014 7:46 am
by Paul Webster
Try this other thread for possible hints on disabling sleep
http://www.raspberrypi.org/forums/viewt ... 6&p=517053
Posted: Sun Sep 14, 2014 7:52 am
by DougieLawson
fuzzweed wrote:Dongle as per link in post above. How / where do I disable power saving? - this sounds like a sensible thing to investigate.
That link doesn't give enough info.
What chipset is your dongle using?
Post the output from a lsusb command.
Posted: Sun Sep 14, 2014 8:20 am
by fuzzweed
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
The linked posts about power saving seem very useful, but I'm having some trouble implementing the suggestions.
This post:
http://www.raspberrypi.org/forums/viewt ... 45&t=46569
Starts with the command:
sudo /etc/network/interfaces
but all I get in return is
sudo: /etc/network/interfaces: command not found
It reads as if I ought to be editing a file; have they missed out launching the file editor from the instructions?
The other option I see is:
sudo iwconfig wlan0 power off
Which does seem to return:
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
But the power off state won't persist through a reboot.
Thanks for your help so far.
Posted: Sun Sep 14, 2014 9:09 am
by DougieLawson
sudo nano /etc/network/interfaces
Add
wireless-power off
Save the file and restart the network or just reboot.
