marcelp1
Re: Got get_iplayer downloading from BBC iPlayer
Thu Jul 26, 2012 9:51 pm
alexeames wrote:Looks like the sequence of the sources.list edits is a lot more crucial than I thought. But delighted it's now working as it should on Raspbian. :D I've now backed up my SD card image as I had some issues getting going with Raspbian and I don't want to go there again. :lol:
Hi alexeames,
thanx for the great tutorial. Any Ideas on how to autostart the get-iplayer-web-pvr
on startup so it is running in the background on headless RPi machine and can
be controlled via the web interface "http://<IP of PI>:1935/" ?
alexeames
Fri Jul 27, 2012 5:59 am
I don't use it myself, but I would imagine it's a question of adding the command...
perl get_iplayer.cgi --port=1935 --getiplayer=/path/to/get_iplayer
...to the startup file. I've forgotten what that's called. I'll look it up :lol:
Is it /etc/rc.local ?
I'll try it and see if it works. :?
This works. add this to rc.local before the last line exit :)
perl /home/get_iplayer/get_iplayer.cgi --port=1935 --getiplayer=/home/get_iplayer/get_iplayer
I believe I read somewhere that this browser based pvr should not be web facing, as it's not very secure, so not a good idea to run it if you are using your pi as a web server. :o
Alex Eames RasPi.TV, RasP.iO
mikerr
Sun Jul 29, 2012 10:02 am
Just for grins I tried streaming...
Video is obviously not up to much:
./get_iplayer --stream Olympics  | mplayer -vfm ffmpeg -lavdopts lowres=0:fast:skiploopfilter=all -nobps -ni -forceidx -mc 0 -
"works", but only at 3fps video or so, audio is perfect though.
Radio stations work great, take your pick:
80100: BBC 1Xtra - live
80101: BBC 5 live Sports Extra- live
80102: BBC 6 Music - live
80103: BBC Asian Network - live
80104: BBC Berkshire - live
80105: BBC Bristol - live
80106: BBC Cambridgeshire - live
80107: BBC Cornwall - live
80108: BBC Coventry & Warwickshire - live
80109: BBC Cumbria - live
80110: BBC Derby - live
80111: BBC Devon - live
80112: BBC Essex - live
80113: BBC Gloucestershire - live
80114: BBC Guernsey - live
80115: BBC Hereford & Worcester - live
80116: BBC Humberside - live
80117: BBC Jersey - live
80118: BBC Kent - live
80119: BBC Lancashire - live
80120: BBC Leeds - live
80121: BBC Leicester - live
80122: BBC Lincolnshire - live
80123: BBC London - live
80124: BBC Manchester - live
80125: BBC Merseyside - live
80126: BBC Newcastle - live
80127: BBC Norfolk - live
80128: BBC Northampton - live
80129: BBC Nottingham - live
80130: BBC Oxford - live
80131: BBC Radio 1 - live
80132: BBC Radio 2 - live
80133: BBC Radio 3 - live
80134: BBC Radio 4 Extra - live
80135: BBC Radio 4 FM - live
80136: BBC Radio 4 LW - live
80137: BBC Radio 5 live - live
80138: BBC Radio Cymru - live
80139: BBC Radio Foyle - live
80140: BBC Radio Nan Gaidheal - live
80141: BBC Radio Scotland - live
80142: BBC Radio Ulster - live
80143: BBC Radio Wales - live
80144: BBC Sheffield - live
80145: BBC Shropshire - live
80146: BBC Solent - live
80147: BBC Somerset - live
80148: BBC Southern Counties - live
80149: BBC Stoke - live
80150: BBC Suffolk - live
80151: BBC Sussex - live
80152: BBC Swindon - live
80153: BBC Tees - live
80154: BBC Three Counties - live
80155: BBC WM - live
80156: BBC Wiltshire - live
80157: BBC World Service - live
80158: BBC York - live
./get_iplayer --stream --type=liveradio 'Sports Extra' |mplayer -
alexeames
Sun Jul 29, 2012 10:27 am
Nice one Mike. I think I read somewhere that a plugin for XBMC (which uses the GPU) can be used to stream BBC iplayer video. Haven't tried it though. :D
mikerr
Sun Jul 29, 2012 11:11 am
Yep - XBMC as a download install to your existing raspbian
http://www.raspberrypi.org/phpBB3/viewt ... 98#p135798
and iplayer add-on works at full frame rate with that.
drgeoff
Sun Jul 29, 2012 4:16 pm
mikerr wrote:Just for grins I tried streaming...
It is probably just ( :) ) a matter of employing the RPi's GPU hardware support for H.264 decoding. But I haven't a clue how to do that :( .
LetHopeItsSnowing
Mon Sep 17, 2012 10:09 pm
Since I've had my Pi, I've been coding a rss feed creator which takes the get_iplayer download history and creates a rss aka podcast feed, which I use to automatically distribute tv and radio programs my mobile phone and XBMC. It works really well if you tie up the PVR function in get_iplayer with creating an rss feed, because you can tell it to download a whole series and it sends it out without you needing to be involved.
Anyway, I've released the alpha version of get_iplayer_genrss and would appreciate some feedback, so head over to http://www.stuffaboutcode.com/p/getiplayergenrss.html to info on how to install and use.
Cheers
LHIS
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
alexeames
Fri Jan 25, 2013 9:25 pm
Just an update here. You can now install get-iplayer on Raspbian without any piddling about...
sudo apt-get update
sudo apt-get install get-iplayer ffmpeg atomicparsley libmp3-info-perl
...and you should be good to go.
Not only that, but one of the Get_iplayer devs has a Pi now and is working on some Pi specific deb files of the latest bleeding edge versions, which, it is hoped will be generally available in due course.
RockSox
Thu Jul 17, 2014 10:54 pm
I've just gotten on the get_iplayer bandwagon....
A few question...
1) Is there a command of renaming the files to their date and removing the title from the file name?
I'm looking to download daily/weekly radio programs and would like to have get_iplayer name the files as "[show]-[date]"
alexeames
Wed Nov 05, 2014 1:27 pm
Update to the Raspberry Pi version (Raspbian) of Get_iplayer, with installation instructions here...
http://raspi.tv/2014/get_iplayer-raspberry-pi-update
Last week the BBC broke some of the most useful Get_iplayer functionality. It's patched already. I tested it this morning. :D
ecotec
Tue Nov 18, 2014 7:28 pm
I can't understand how I haven't seen this before, but i've spent a few days getting to grips with it and its great. The issue for me now is storage space, I have filled my small usb stick and want to use an old external HDD I have instead.
So what would be the best format for the HDD ex3 or ex4 or something else?
b raspbian running get-iplayer and mini dlna server
b+ running volumio
pi 2 - dietpi - pihole, ssh and a few other bits
ecotec
Fri Nov 21, 2014 9:01 pm
^formatted to ex4 and all working fine,
b+ running volumio
Return to “Media centres”
