Fri Jan 03, 2014 1:03 pm
CEC fails after Sharp tv is turned off.Using Raspberry pi with openelec 3.2.4. Remote.xml works fine when hard reboot, changing input source works, but when Sharp tv is power off, remote.xml will not work. Have notice if leaving content menu on when powering off tv and turn on that the content menu is still there and works for the first time but will not work after using content menu there after. Have also notice that when doing a hard reboot that the sharp tv has to be on to the assocated input for cec to start working. Config file: hdmi_ignore_cec_init=1, hdmi_force_hotplug=0, hdmi_group=1, hdmi_mode=16, have made changes from 0 to 1 and no effect to problem, still get no input selection available when selecting a remote.xml keyfuction.
