texy
XBMC, LCDproc, 44780 LCD (I2C)
Sun Dec 15, 2013 1:00 pm
A short tutorial using a hd44780 I2C based LCD with Raspbmc.
SSH into the pi and install LCDproc and i2c-tools :
sudo apt-get install lcdproc i2c-tools -y
Enable i2c on the pi :
sudo nano /etc/modules
and add
i2c-bcm2708
i2c-dev
You need to configure LCDproc for your particular display and connection method. Edit /etc/LCDd.conf :
sudo nano /etc/LCDd.conf
Within the Server section change to :
[Server]
Driver=hd44780
ServerScreen=no
and change the [hd44780] section to :
[hd44780]
# Select what type of connection. See documentation for types.
ConnectionType=i2c
# Port where the LPT is. Usual value are: 0x278, 0x378 and 0x3BC
Port=0x20
# Device of the serial interface [default: /dev/lcd]
Device=/dev/i2c-1 # make this i2x-0 for Revision 1 Pi's
# Bitrate of the serial port (0 for interface default)
Speed=0
# If you have a keypad connected.
# You may also need to configure the keypad layout further on in this file.
Keypad=no
# Set the initial contrast (bwctusb and lcd2usb) [default: 500; legal: 0 - 1000]
Contrast=0
# Set brightness of the backlight (lcd2usb only) [default: 0; legal: 0 - 1000]
#Brightness=1000
#OffBrightness=0
# If you have a switchable backlight.
Backlight=no # it's reversed for this display, so no really means yes !
# If you have the additional output port ("bargraph") and you want to
# be able to control it with the lcdproc OUTPUT command
OutputPort=no
# Specifies if the last line is pixel addressable (yes) or it controls an
# underline effect (no). [default: yes; legal: yes, no]
#Lastline=yes
# Specifies the size of the LCD.
# In case of multiple combined displays, this should be the total size.
Size=20x4
# For multiple combined displays: how many lines does each display have.
# Vspan=2,2 means both displays have 2 lines.
#vspan=2,2
# If you have an HD66712, a KS0073 or another 'almost HD44780-compatible',
# set this flag to get into extended mode (4-line linear).
#ExtendedMode=yes
# In extended mode, on some controllers like the ST7036 (in 3 line mode)
# the next line in DDRAM won't start 0x20 higher. [default: 0x20]
#LineAddress=0x10
# Character map to to map ISO-8859-1 to the LCD's character set
# [default: hd44780_default; legal: hd44780_default, hd44780_euro, ea_ks0073,
# sed1278f_0b, hd44780_koi8_r, hd44780_cp1251, hd44780_8859_5, upd16314 ]
# (hd44780_koi8_r, hd44780_cp1251, hd44780_8859_5 and upd16314 are possible if
# compiled with additional charmaps)
CharMap=hd44780_default
# LCDd, garbage can appear on the LCDd. Set this delay factor to 2 or 4
# to increase the delays. Default: 1.
#DelayMult=2
# Some displays (e.g. vdr-wakeup) need a message from the driver to that it
# is still alive. When set to a value bigger then null the character in the
# upper left corner is updated every <KeepAliveDisplay> seconds. Default: 0.
#KeepAliveDisplay=0
# If you experience occasional garbage on your display you can use this
# option as workaround. If set to a value bigger than null it forces a
# full screen refresh <RefreshDiplay> seconds. Default: 0.
#RefreshDisplay=5
# You can reduce the inserted delays by setting this to false.
# On fast PCs it is possible your LCD does not respond correctly.
# Default: true.
DelayBus=false
# If you have a keypad you can assign keystrings to the keys.
# See documentation for used terms and how to wire it.
# For example to give directly connected key 4 the string "Enter", use:
#   KeyDirect_4=Enter
# For matrix keys use the X and Y coordinates of the key:
#   KeyMatrix_1_3=Enter
KeyMatrix_4_1=Enter
KeyMatrix_4_2=Up
KeyMatrix_4_3=Down
KeyMatrix_4_4=Escape
After those changes reboot the pi.
XBMC now supports a python based application to communicate with LCDproc so make sure that LCD/VFD is disabled in System/Settings/Video menu otherwise the services will clash.
You can download the installation script from here : https://github.com/herrnst/script.xbmc. ... master.zip. I copied it to a usb drive and then used the
install from zip method from the System/settings/Add-ons menu. Then go to the configuration page for XBMC LCDproc via System,Settings, Add-ons. XBMC LCDproc, Configure. The only thing you should need to adjust is the Delay for scrolling text as by default it is too fast too read. I also disabled the Show heartbeat symbol, but that's up to you.
Also when XBMC goes into screensave mode, the display shows the time :
Texy
Pijus Magnificus
Re: XBMC, LCDproc, 44780 LCD (I2C)
Tue Dec 17, 2013 12:20 pm
Hello mate.
This tutorial helps me to my problem?
Only I have to install the zip file?
It is the same screen lcd?
Thank you.
Copy/paste:
First apologize for my English, I use google translator.
I bought this screen, thinking it would be plug and play, but far from reality, now I'm lost, I have also opened several fronts and I'm a bit saturated:
https://www.modmypi.com/raspberry-pi-RG ... r_name=lcd
I have installed OpenELEC of modi, and installing this screen or turn on. I had to install Raspbian, and I followed this tutorial Manufacturer:
http://learn.adafruit.com/adafruit-16x2 ... y-pi/usage
Now turn on, but only square displayed on the screen, and no longer continue, I reinstalled OpenELEC and I have configured in the system vfd screen and LCD HD44780 model but still with squares and not show any information . Can anyone help me?
Thank you.
texy
Tue Dec 17, 2013 7:35 pm
No the board in the fist post is of my own design.
The link for modmypi is incomplete?
Texy
texy
Actually both of the links are incomplete.
Texy
Pijus Magnificus
Tue Dec 17, 2013 8:00 pm
Sorry, the ldc screen:
Tutorial:
I have now reconnected the raspberry with lcd screen, and it will not turn on again. :(
exzile
Sun Oct 05, 2014 4:03 am
Texy this program you have is the only one that will make my LCD print text. QC1602A is the model.
All other libraries don't seem to work that I have found through google. I've tried many....
Is there a way to get the source code so I can use it as an engine to talk to my LCD?
texy
Sun Oct 05, 2014 8:34 am
I have no connection with LCDproc. I suggest you "google LCDproc source" and see what comes up.
Texy
Return to “Media centres”
