snag4
Duplicate entries on XBMC using MySQL
Sun Sep 22, 2013 3:16 pm
I am running MySQL on a Raspi. I am also running XBMC on 2 Raspi's. When I first installed MySql and borught up the first XBMC, everything worked great. When I bring up the second Raspi with XBMC, I start getting duplicate entries for my TV shows. Everythign still works correctly in the way of marking of watched shows/playback/resume. I am running XBMC 3.0.6 but it has happened on previous versions alsso.
I use the same advancedsettings.xml file on both units. Any idea what I am doing wrong?
TIA...
Takenover83
Re: Duplicate entries on XBMC using MySQL
Mon Sep 23, 2013 3:19 am
I was having the same problem. But then I learned not to add sources on the 2nd Pi. All it needs is the advancedsettings.xml that points to your mysql server.
Return to “Media centres”
