Museste
Open Elec 3.2.0
Sat Sep 14, 2013 1:37 am
Ok so i,ve downloaded the the raspberry pi version of Open Elec 3.2.0 from the official site and its not an img file as im used too. Can anyone give me an explanation on how I set it up on my SD card.
Im using Windows 7
Speedwell68
Re: Open Elec 3.2.0
Sat Sep 14, 2013 1:03 pm
No idea in Windows, I'm not a Windows user TBH. I'd just do it with NOOBS.
elver
Re: Open Elec 3.2.0
Sat Sep 14, 2013 4:56 pm
Just spent the last hour learning how to make a virtual machine of ubuntu on windows then creating an image file inside there, I didn't know anything about the universal installer, oh well, I suppose learning is good. If the NOOBS doesn't work for you I can send you my img file I created if you want.
Museste
Re: Open Elec 3.2.0
Sun Sep 15, 2013 12:30 am
Thanks for the link :-) last time i did indeed use noobs. Now it auto updates this makes things a lot easier
Speedwell68
Re: Open Elec 3.2.0
Sun Sep 15, 2013 12:53 pm
Glad you got it working. I have to say I am very impressed with Openelec 3.2.0, it is a huge improvement over 3.0.x.
cyber7
Re: Open Elec 3.2.0
Mon Sep 16, 2013 1:30 pm
I have created a section of how to install OpenElec from Windows. Follow the http://wiki.openelec.tv/index.php?title ... ith_issues (Windows SD Card with issues, but create cmdline.txt with the Standard Card installation instruction.)
Very easy and quick...
c7ber7-out
Speedwell68
Re: Open Elec 3.2.0
Mon Sep 16, 2013 2:26 pm
ednl wrote:
Speedwell68 wrote:I have to say I am very impressed with Openelec 3.2.0, it is a huge improvement over 3.0.x.
Can you tell how, what makes a difference to you as a user? I am trying to find such info on recent versions of both Openelec and Raspbmc.
The Openelec Settings Addon is way better than before, the interface is much more user friendly and it is easier to configure networks and bluetooth devices, It boots faster than before and the operation of it is much smoother, Also I notice that the System Info screens now work properly, before it reported my Pi as have an 800Mhz CPU speed regardless of load, I guess because I overclocked it to 800Mhz. Now when idle it reports a 700Mhz CPU speed and only reports it going up to 800Mhz when under load, as it should. In version 3.0.x the CPU usage indicator never showed below 90% usage, even though I had modified my Avancedsettings.xml to reduce CPU usage at idle, now it indicates 25% to 30% CPU usage at idle.
They are the improvements over 3.0.x I have noticed, I can't compare it to RaspBMC as I have never used it.
castalla
Re: Open Elec 3.2.0
Mon Sep 16, 2013 3:07 pm
I generally use Raspbmc - overall it's much faster and fluid than either xbian or openelec Also, there is an ongoing series of regular updates
edit: just installed OE 3.2 - very good ... may switch to this from raspbmc!
Return to “Media centres”
