sraue
Re: OpenELEC meets Raspberry Pi - part 1 (XBMC)
Fri Jun 01, 2012 8:15 pm
LastSilmaril wrote:Compile fails again (gets much further this time).
https://dl.dropbox.com/u/268147/rpi/log_r11198.7z
should be fixed now, its enough if you restart the make process after a
git pull origin master
LastSilmaril
Fri Jun 01, 2012 8:29 pm
OK, trying again.
patboyx
Fri Jun 01, 2012 9:52 pm
So I had everything working fine until I switched to "Windowed" mode.
Now I can't switch it back. Hitting either arrow (up or down) simply asks me if I want to keep the current resolution.
Any ideas?
nabla
Fri Jun 01, 2012 10:09 pm
So far I tried compiling three times and it always fails... Is it because I want it with PVR?
LastSilmaril
Fri Jun 01, 2012 10:15 pm
OK, trying again.
Still fails. This time, something to do with python 2.7.3
https://dl.dropbox.com/u/268147/rpi/log_newest.7z
sraue
Fri Jun 01, 2012 10:16 pm
nabla wrote:So far I tried compiling three times and it always fails... Is it because I want it with PVR?
possible, we dont have PVR support for the RPi builds
nabla
Fri Jun 01, 2012 10:24 pm
Thanks for the answer sraue.
Is it likely you will support PVR in the future?
sraue
Fri Jun 01, 2012 10:29 pm
nabla wrote:Thanks for the answer sraue.
maybe but thats far away first there must still be much work done on the xbmc-rpi port, *i think* until its merged to xbmc's master branch there will be not much work on this.
funnel
Fri Jun 01, 2012 10:35 pm
patboyx wrote:So I had everything working fine until I switched to "Windowed" mode.
Any ideas?
In guisettings.xml the line you edited
<screenmode>WINDOW</screenmode>
change to
<screenmode>DESKTOP</screenmode>
or just delete guisettings.xml, it will be recreated after a reboot with default settings.
sraue
Fri Jun 01, 2012 11:03 pm
luenser wrote:Thanks for the build, installed it within minutes and fired up my RPi for the first time. Unfortunately, I get locked in a boot-cycle, I can see the OpenELEC-logo, some kind of color calibration and every now and then a glimpse of xbmc - before it reboots again. Any ideas on that?
i think it can have to do with the powersupply?
LastSilmaril
Sat Jun 02, 2012 2:12 am
Just got the same error again.
onetootreefor
Sat Jun 02, 2012 6:08 am
humla wrote:
BrightonGuy wrote:If it helps, I am now having the same build issue - my build environment is
Linux xxxxs 2.6.32-5-686 #1 SMP Sun May 6 04:01:19 UTC 2012 i686
on a Lenovo T23 laptop!
You can fix this problem by executing this when you get this error(as said by others in this thread). Run it from the Openelec.tv folder
cp build.OpenELEC-RPi.arm-devel/Python-2.7.3/.objdir-target/libpython2.7.so* build.OpenELEC-RPi.arm-devel/Python-2.7.3/.objdir-target/Modules/
wumpyr
Sat Jun 02, 2012 8:25 am
Used to build fine on gentoo, now shows:
checking for gelf_getvernaux... no
checking whether FTW_ACTIONRETVAL is supported... yes
checking for is_selinux_enabled in -lselinux... no
checking selinux/selinux.h usability... no
checking selinux/selinux.h presence... no
checking for selinux/selinux.h... no
configure: error: libelf does not properly convert Elf64_Sxword quantities.
If you are using libelf-0.7.0, please use patches/libelf-0.7.0.patch.
make: *** [system] Errore 3
My system has elfutils-0.153 installed. Is this bogus or does elfutils need a patch too?
elektrobank
Sat Jun 02, 2012 10:50 am
Piminiuser wrote:
Nodge wrote:Hi All,
I've just installed the R11170 image (from someones dropbox from an earlier post). All looks good except that I can't see my external hard drive plugged into the USB port. I've tried a memory stick and I've tried swapping over usb ports but still can't see them.
Earlier today I tried Rasbmc and that could see the drive ok. I'm completely new to Linux and wasn't sure where I should have been looking anyway, but with Raspbmc when I went to "Add Source" I found my drive under Root filesystem/media/usb. (Under media there was a list of USB, USB0, USB1 etc) Is this where it's supposed to be located? With OpenElec though there are no USB entries listed under Root filesystem/media/ and I couldn't see the drive anywhere else. So is it me, or has something gone wrong somewhere?
Thanks,
John
Same problem here.
Same problem here.
LastSilmaril
Sat Jun 02, 2012 3:45 pm
Thank you, somehow missed those posts. Let's see if it works this time.
onetootreefor
Sat Jun 02, 2012 5:12 pm
ok so i compiled fine! i have the newest build as of 6/2, and I am trying to update manually by putting the Kernel and System in the Update folder. When I do this the kernel/system are recognized but it skips update do to lack of md5 checksums. There were no md5's generated during my build so how can I skip this for beta updates?
humla
Sat Jun 02, 2012 6:19 pm
onetootreefor wrote:ok so i compiled fine! i have the newest build as of 6/2, and I am trying to update manually by putting the Kernel and System in the Update folder. When I do this the kernel/system are recognized but it skips update do to lack of md5 checksums. There were no md5's generated during my build so how can I skip this for beta updates?
instead of doing PROJECT=RPi ARCH=arm make add a release at the and and you should get a .tar.bz2 file in the Openelec.tv/target folder. Untar it (tar xjvf) and then look at the target folder inside it.
onetootreefor
Sat Jun 02, 2012 6:26 pm
humla wrote:instead of doing PROJECT=RPi ARCH=arm make add a release at the and and you should get a .tar.bz2 file in the Openelec.tv/target folder. Untar it (tar xjvf) and then look at the target folder inside it.
thanks so much! worked like a charm its updating now!
basst85
Sat Jun 02, 2012 9:59 pm
Download OpenELEC r11203 image files (for 2 and 4 GB SDcards) here:
http://www.basst.nl/?p=591
LastSilmaril
Sat Jun 02, 2012 11:45 pm
So I just managed to do that twice, but this is annoying, as every time I want to recompile cleanly I have to let it go, wait for it to fail, copy the requisite files, and run the compile again - unless I don't run an initial "make clean". It's a time-waster.
sraue
Sat Jun 02, 2012 11:56 pm
i will look at this the next days, does this ^^^ workaround help and you have after doing this *.so files in build.OpenELEC-RPi.arm-devel/Python-2.7.3/.objdir-target/Modules ? can you paste (on a pastebin site the output from "ls build.OpenELEC-RPi.arm-devel/Python-2.7.3/.objdir-target/Modules/*" ?
onetootreefor
Sun Jun 03, 2012 12:09 am
it might be a pain, but im 100% sure it will be fixed in the next build...its only a temporary solution to a temporary problem.
LastSilmaril
Sun Jun 03, 2012 4:56 am
Of course, of course, I just like complaining :)
notzippy
Sun Jun 03, 2012 5:04 am
Fix for me was to do this to fix the "libelf does not properly convert Elf64_Sxword quantities."
sudo apt-get install libelfg0-dev
wumpyr wrote:Used to build fine on gentoo, now shows:
luenser
Sun Jun 03, 2012 9:16 am
Yes, that was it - with a different power cable and a real usb-keyboard it stops rebooting. Was using some kind of adapter for usb to ps2 before..
Unfortunately, I still got issues regarding the keyboard. XBMC starts up and I can navigate with keys and touchpad. Once I go inside System settings, the cursor disappears and XBMC doesn't respond to any key. What I _can_ do is rebooting the system with ctrl-alt-del, so the connection to the keyboard doesn't seem to be interrupted in general.
Have no idea how to solve this..
Return to “Media centres”
