abishur
Re: Bulding XBMC for Raspberry Pi
Thu Apr 26, 2012 9:13 pm
gimli said:
Abishur said:
Still, this is an xbmc problem more than an R-pi one I believe.
In this case it wi'll be more the PI ports fault. Maybe it is fixed with the player rework i do here.
ah, then my information *was* outdated
Dear forum: Play nice ;-)
dom
Thu Apr 26, 2012 9:30 pm
@abishur can you remux the file without the subtitles and see if it plays?
Tavalin
Thu Apr 26, 2012 10:12 pm
Has anyone tried enabling dirty regions (assuming it's not already enabled) to see if it speeds up the menus?
abishur
Thu Apr 26, 2012 10:18 pm
Crap, that worked. I literally have hundreds of files and I really don't want to have to remove subtitles from all of them to get this working.  I tried setting showsubtitles to false in .xbmc/userdata/guisettings.xml but that didn't work I saw a suggestion about going into Movie Options and Set Enable Subtitles to off but I can't seem to find such an option
dom
Thu Apr 26, 2012 10:38 pm
@abishur http://forum.xbmc.org/showthre.....tid=125865
I"m sure the subtitle issue will be fixed soon, but you may be able to disable them for now.
abishur
Thu Apr 26, 2012 10:48 pm
No dice, even with subtitles disabled from the get go it crashes.  It must be something about how my subtitles are included in the file (I think handbrake is using VobSub)
Tavalin
Thu Apr 26, 2012 11:00 pm
Just tried this, it didn't work out as well as I'd hoped!  The usage of dirty regions did seem to speed up the navigation between menus but the frame buffers seems to empty meaning that the non-dirty regions ended up blank with only the dirty regions getting painted on screen.
dom
Probably in the file reading side, rather than subtitle rendering.
A 100M sample of the file that exhibits the issue would be useful (for gimli).
abishur
Fri Apr 27, 2012 12:27 am
I had to compress it a lot to get it down to around 100 MB, but here's a link to the dropbox file
Here's the media info from it as well
General
Unique ID                                : 307125793196953809258474163730858316859 (0xE70E46B3CF22C074D82C16B21A97143B)
Complete name                            :
Format                                   : Matroska
Format version                           : Version 2
File size                                : 106 MiB
Duration                                 : 42mn 42s
Overall bit rate                         : 347 Kbps
Writing application                      : HandBrake 0.9.6
Writing library                          : libmkv 0.6.5
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L3.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 42mn 42s
Width                                    : 720 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 16:9
Original display aspect ratio            : 16:9
Frame rate mode                          : Variable / Variable
Frame rate                               : 59.940 fps
Standard                                 : NTSC
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Writing library                          : x264 core 120
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=600 / keyint_min=60 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=30.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color primaries                          : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics                 : BT.709-5, BT.1361
Matrix coefficients                      : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : A_AAC
Duration                                 : 42mn 42s
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Compression mode                         : Lossy
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : The same subtitle format used on DVDs
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
00:00:00.000                             : Chapter 1
00:05:16.632                             : Chapter 2
00:14:24.179                             : Chapter 3
00:31:54.896                             : Chapter 4
gimli
Fri Apr 27, 2012 7:01 am
General
Complete name                            :
Format                                   : Matroska
File size                                : 106 MiB
Duration                                 : 42mn 42s
Video
Format                                   : AVC
Duration                                 : 42mn 42s
Width                                    : 720 pixels
Height                                   : 480 pixels
Standard                                 : NTSC
Color space                              : YUV
Bit depth                                : 8 bits
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : AAC
Format profile                           : LC
Codec ID                                 : A_AAC
Duration                                 : 42mn 42s
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Language                                 : English
Default                                  : No
Forced                                   : No
Menu
Works with the new player code here
Blunderbuss
Fri Apr 27, 2012 7:57 am
So I copied the folder and driver over, but running it it now says that I cannot run XBMC unless the screen color depth is 24bit, and I need to reconfigure it. Anyone know how to fix this?
GroundhogOZ
Fri Apr 27, 2012 9:28 am
I played around with Liams-Image yesterday and playing a complete movie in 720p or less via network was no problem.
Today I tried with 2 different 1080p-MKVs and got a freeze after some minutes.
I'm not sure if I have temperature issues because the Raspi caught a little bit too much of the sun or if there is a general problem with the image somebody can reproduce.
dom
Fri Apr 27, 2012 10:51 am
It is not temperature (we"ve run these chips in an oven at 80degC playing 1080p for weeks).
Most likely power supply (probably not enough current, less likely not enough voltage). Can you try swapping power supply/USB cable?
GroundhogOZ
Fri Apr 27, 2012 12:33 pm
I'm using the cable of my smartphone (HTC) which should deliver enough power:
http://www.almedia.tv/bilder/p.....5109_1.jpg
When I'm back at home I will see if I can find a different cable and try again.
abishur
Fri Apr 27, 2012 12:45 pm
I see, how do I get that new code onto my pi?
gimli
Fri Apr 27, 2012 12:50 pm
Looks like it depends on me, when i'm going to push it
Tavalin
Fri Apr 27, 2012 12:54 pm
Could it be that the RPi isn't powerful enough?  I've tried to play a few 1080p mkvs and after a while it freezes too but I just attributed that to the fact it was too much for the RPi.
Kushan
Fri Apr 27, 2012 1:42 pm
I don't think CPU/GPU power is the issue, as far as I know the decoding is done in hardware and the Pi is more than capable of it (early testers said they could play 1080p without an issue). I dare say it's likely something relating to I/O throughput or something else, in any case I'm sure it can be fixed.
GroundhogOZ
Fri Apr 27, 2012 1:47 pm
I don't think the performance is a problem … then it would be problematic from the start of the film.
I streamed it from a local server (Windows-network) and will try it from a different source (usb) when I have time and a new HDMI-cable to see if it is a network-issue.
abishur
Fri Apr 27, 2012 2:02 pm
::Waits patiently:: Once it is out there, will it be as simple as running an update or will we need to go through the whole cross-compile again? (I love how i say again as if I did it the first time instead of being lazy and using Liam's image )
Tavalin
Fri Apr 27, 2012 2:19 pm
GroundhogOZ said:
I don"t think the performance is a problem … then it would be problematic from the start of the film.
For the ones I tried the film stuttered sporadically from the start (and this was repeatable each time i restarted the film) before freezing when I tried to get back to the menu.  Maybe they're different issues then.
GroundhogOZ
Fri Apr 27, 2012 2:24 pm
The movie was running completely fine for me until the freeze. I haven't tried to go back to the menu with the 1080p-file.
Did you stream it from a network-destination or a USB-device?
Tavalin
Fri Apr 27, 2012 2:37 pm
A windows share (smb)
dom
Fri Apr 27, 2012 3:09 pm
You will get much better performance with an nfs share
You can also stream with ftp and http with XBMC, and they will be better than SMB.
nfs mounting with these options:
mount 192.168.4.9:/Public -o rw,vers=3,rsize=8192,wsize=8192,soft,nolock,udp /home/pi/dell
gave good results.
I'm actually using Hanewin NFS server on Windows 7.
GroundhogOZ
Fri Apr 27, 2012 3:15 pm
gave good results.
Thank you I will try it, but I couldn't change too much on the server at work, so that's my homework to test it.
Maybe that will solve Tavalins and my problem.
Do you know how the performance with a USB-device is?
Return to “Media centres”
Who is online
Users browsing this forum: No registered users and 3 guests
