I need a little help getting a gst-launch-1.0 command to work on the RPi.
I have a DVB-T USB adaptor, which I know works OK with the RPi because Kaffeine works - although it's too slow to be useful.
So, I now have GStreamer 1.0 installed, and I need a little help getting to watch live DVB-T tele.
Here is what I have got so far:
gst-launch-1.0 dvbsrc modulation="QAM 64" trans-mode=8k bandwidth=8 frequency=658000000 code-rate-lp=AUTO code-rate-hp=2/3 guard=4 hierarchy=0 ! tsdemux name=demux ! queue max-size-buffers=0 max-size-time=0 ! h264parse ! omxh264dec ! eglglessink
I know that the frequency is right, because the DVB-T locks on OK.
And, anyway, using w_scan found channels on that frequency.
But, my problem is that the gst-launch-10 doesn't actually do anything.
I just see this :
Setting pipeline to PAUSED...
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': context, gst.egl.EGLDisplay=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
<-- Waits here for about 2 mins -->
Then, I get an error about internal data flow, then it quits.
So, what is wrong?!?!?
Help appreciated.
Regards
Nick
Re: GStreamer dvbsrc pipeline example.
Have a look at the gst-launch debug options to get more details on where it is failing by doing a man gst-launch-1.0nickon314 wrote:Hi,
I just see this :
Help appreciated.
In particular look at the options:
--gst-debug-level=
--gst-debug-string=
I'd also add the -v and -e parameters to the gst-launch-1.0 command.
It would also be useful if you could provide the make and model of your DVB-T USB adaptor in case anyone here is using the same one.
The USB DVB-T device looks like this from 'lsusb' :
Bus 001 Device 005: ID 048d:9135 Integrated Technology Express, Inc. Zolid Mini DVB-T Stick .
I will look at those debug options now too.
Regards
Nick
Regards
Nick
Using --gst-debug-level=4, I'm seeing a lot of these lines repeated:
0:00:07.102109788 2669 0xacdac0 WARN mpegtspacketizer mpegtspacketizer.c:3483:calculate_skew: delta - skew: 5124071:07:03.454236357 too big, reset skew
And, another similar one that says "backward timestamps at server but no timestamps"
Is that significant?
Regards
Nick
Regards
Nick
I've also tested the videotestsrc too, to make sure that I see the colour bars OK. And that works OK using this:
gst-launch-1.0 videotestsrc ! textoverlay text="Hello" ! eglglessink
So, the problem I am having must be somewhere in the pipeline relating to tuning and demuxing and decoding.
Regards
Nick
Regards
Nick
Yeah, your best bet would be googling on the warning message or on the pipeline element names to find examples of other working similar pipelines.nickon314 wrote:I've also tested the videotestsrc too, to make sure that I see the colour bars OK. And that works OK using this:
