nickon314
GStreamer dvbsrc pipeline example.
Fri May 24, 2013 4:00 pm
I need a little help getting a gst-launch-1.0 command to work on the RPi.
I have a DVB-T USB adaptor, which I know works OK with the RPi because Kaffeine works - although it's too slow to be useful.
So, I now have GStreamer 1.0 installed, and I need a little help getting to watch live DVB-T tele.
Here is what I have got so far:
gst-launch-1.0 dvbsrc modulation="QAM 64" trans-mode=8k bandwidth=8 frequency=658000000 code-rate-lp=AUTO code-rate-hp=2/3 guard=4 hierarchy=0 ! tsdemux name=demux ! queue max-size-buffers=0 max-size-time=0 ! h264parse ! omxh264dec ! eglglessink
I know that the frequency is right, because the DVB-T locks on OK.
And, anyway, using w_scan found channels on that frequency.
But, my problem is that the gst-launch-10 doesn't actually do anything.
I just see this :
Setting pipeline to PAUSED...
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': context, gst.egl.EGLDisplay=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
<-- Waits here for about 2 mins -->
Then, I get an error about internal data flow, then it quits.
So, what is wrong?!?!?
Help appreciated.
Regards
Nick
fbutler
Re: GStreamer dvbsrc pipeline example.
Fri May 24, 2013 4:18 pm
nickon314 wrote:Hi,
I just see this :
Help appreciated.
Have a look at the gst-launch debug options to get more details on where it is failing by doing a man gst-launch-1.0
In particular look at the options:
--gst-debug-level=
--gst-debug-string=
I'd also add the -v and -e parameters to the gst-launch-1.0 command.
It would also be useful if you could provide the make and model of your DVB-T USB adaptor in case anyone here is using the same one.
nickon314
Mon Jun 03, 2013 8:01 am
The USB DVB-T device looks like this from 'lsusb' :
Bus 001 Device 005: ID 048d:9135 Integrated Technology Express, Inc. Zolid Mini DVB-T Stick .
I will look at those debug options now too.
Regards
Nick
nickon314
Mon Jun 03, 2013 8:24 am
Using --gst-debug-level=4, I'm seeing a lot of these lines repeated:
0:00:07.102109788 2669 0xacdac0 WARN mpegtspacketizer mpegtspacketizer.c:3483:calculate_skew: delta - skew: 5124071:07:03.454236357 too big, reset skew
And, another similar one that says "backward timestamps at server but no timestamps"
Is that significant?
Regards
Nick
nickon314
Mon Jun 03, 2013 10:20 am
I've also tested the videotestsrc too, to make sure that I see the colour bars OK. And that works OK using this:
gst-launch-1.0 videotestsrc ! textoverlay text="Hello" ! eglglessink
So, the problem I am having must be somewhere in the pipeline relating to tuning and demuxing and decoding.
Regards
Nick
fbutler
Mon Jun 03, 2013 10:30 am
nickon314 wrote:I've also tested the videotestsrc too, to make sure that I see the colour bars OK. And that works OK using this:
Yeah, your best bet would be googling on the warning message or on the pipeline element names to find examples of other working similar pipelines.
Return to “Media centres”
