TheShryke
Media center in a 3.5" HDD enclosure
Tue May 14, 2013 8:18 pm
Quick question, I am thinking of putting a pi + a 2.5" HDD into a 3.5" HDD enclosure. I am planning to power the pi from the 5v line of the power supply for the enclosure. The supply is rated for 5v @ 2A and 12v @ 2A, I would only be using the 5v line for the pi obviously, would there be enough current to run the pi and the drive? I would be using a Wi-Fi dongle and possibly a wireless keyboard too.
If successful this will sit under the TV as a nice small media center running XBMC :D
TheShryke
Re: Media center in a 3.5" HDD enclosure
Wed May 22, 2013 10:52 pm
Anyone?
clive
Wed May 22, 2013 11:44 pm
Over a week since you had a really good idea and you've not been even a tiny bit tempted to jury-rig it to test it? ;)
The simple answer is that it's feasible but it depends on the enclosure and it's power supply. So test it! (And let us know how you got on :)) As long as the Pi doesn't get more than 5v it can't hurt it. It should make for a nice media centre.
TheShryke
Thu May 23, 2013 9:33 am
I'm still waiting on a micro USB cable to cut up to try powering the pi, plus this is one of several projects I have going right now :D I was just wondering if anyone knew anything on the topic. Ill see if I can try powering the pi through the GPIO tonight.
Oh one more question, would the wi-fi dongle still get signal inside a close metal case?
ski522
Thu May 23, 2013 11:08 am
Well, the Pi on average requires about 750mA, how much power does the drive you plan on using require? Add the 2 together, if you're under 2A then you're good to go.
TheShryke
Thu May 23, 2013 3:35 pm
Tested and it seemed to work fine :D I had the pi playing HD movies from a 2.5" hard drive, no wifi, but ill try that soon.
@ski522 Its a shame I didn't see your post sooner, for some reason I completely forgot to check if the drive had a current draw listed on it. I checked after the test and its rated at 0.5A. My pi works fine with the wi-fi when I use a 1A power supply so even if its maxing that supply out (Doubtful) then that still leaves me with a spare 500mA from the HDD supply so thats good :D
That just leaves me to find out if the wi-fi to get signal and if there will be a heat issue in such a tight enclosed space.
RaTTuS
Thu May 23, 2013 3:46 pm
I've been running a model B 256Mb in a 3.5" drive case with a 2.5" drive for several months [routed the +5 volt line to the RPi] I was using the wired socket
I've just this week disassembled it to replace it with a
Model A and a Camera ;)
no issues
Covfefe
TheShryke
Thu May 23, 2013 3:51 pm
Good to know! Thanks :D
Were you using A wi-Fi dongle, and if so, did you encounter any signal issues from the casing?
RaTTuS
Thu May 23, 2013 4:05 pm
no I used wired network - in the current config I dont have any network - I do need to tify it up as it's got wires coming out of the case every side ATm
Covfefe
TheShryke
Thu May 23, 2013 4:17 pm
Ah ok, ill just have to experiment with that one then.
TheShryke
Thu May 23, 2013 10:23 pm
It works! :D
I couldnt get wifi working, but thats not a casing issue, it just doesnt work.
On that note, does anyone have any tips on getting RTL8188CUS based dongles to work in OpenELEC?
roroid
Thu Aug 08, 2013 12:41 pm
Sorry for reopening the topic but I want to do the same thing. Can you please tell me if the HDD stops with the shut down of the Pi? What HDD rack are you using?
Thanks.
Return to “Media centres”
