EDV11
Raspberry Pi will not play AVC L4.1 file
Thu Mar 07, 2013 9:40 pm
I have reencoded The Dark Knight movie as it was completely unwatchable on the Pi. Very chopy when playing, very high bitrate.
Anyway, I reencoded the video file to h264 and, with mkvmerge, I change the original VC1 video file to the new, smaller h264. I didn't change any sound file.
I have tested the video file with other video players, as well as with other XBMC players (on Mac and iPad) and it would play just fine. When I try to play it on the Pi, it starts loading, goes to black screen but doesn't start. If I click on the remote, I get the info (so it's not hung up), and it would not play, it gets stopped at 0:00, no matter what I do.
This is the file info
General
Unique ID                                : 297972976087008896263909637394324165860 (0xE02B81FA5BBCAFAADD59D23C0AD694E4)
Complete name                            : /Volumes/Qmultimedia/Películas/HD/El Caballero Oscuro/Batman, El Caballero Oscuro.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 18.4 GiB
Duration                                 : 2h 32mn
Overall bit rate mode                    : Variable
Overall bit rate                         : 17.3 Mbps
Encoded date                             : UTC 2013-03-06 15:57:52
Writing application                      : mkvmerge v6.1.0 ('Old Devil') built on Mar  2 2013 22:22:31
Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Baseline@L4.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Format settings, GOP                     : M=1, N=12
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 2h 32mn
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Default                                  : Yes
Forced                                   : No
Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Duration                                 : 2h 32mn
Bit rate mode                            : Constant
Bit rate                                 : 640 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 697 MiB (4%)
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : TrueHD
Codec ID                                 : A_TRUEHD
Duration                                 : 2h 32mn
Bit rate mode                            : Variable
Maximum bit rate                         : 3 267 Kbps
Compression mode                         : Lossless
Default                                  : No
Forced                                   : No
Audio #3
Format                                   : AC-3
Format profile                           : Dolby Digital
Codec ID                                 : A_AC3
Duration                                 : 2h 32mn
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Bit depth                                : 16 bits
Stream size                              : 209 MiB (1%)
Default                                  : No
Forced                                   : No
Audio #4
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 2h 32mn
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Stream size                              : 488 MiB (3%)
Default                                  : No
Forced                                   : No
Audio #5
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 2h 32mn
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Default                                  : No
Forced                                   : No
Audio #6
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 2h 32mn
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Default                                  : No
Forced                                   : No
Audio #7
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 2h 32mn
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Default                                  : No
Forced                                   : No
Audio #8
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 2h 32mn
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Default                                  : No
Forced                                   : No
Audio #9
Format                                   : AC-3
Codec ID                                 : A_AC3
Duration                                 : 2h 32mn
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Default                                  : No
Forced                                   : No
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
Default                                  : Yes
Forced                                   : No
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #3
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #4
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #5
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #6
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #7
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #8
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #9
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #10
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #11
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #12
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #13
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #14
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #15
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #16
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #17
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #18
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #19
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #20
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #21
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #22
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #23
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Text #24
Format                                   : PGS
Muxing mode                              : zlib
Default                                  : No
Forced                                   : No
Why is the Pi not being able to play this file, and other XBMC players do it with no hesitation? Even the iPad can play it, and with the original m2ts file it was even worse than the Pi.
If it is a codec 'thingy', which one should I use? I also want to reencode Inception, as it has very high bitrate (in VC1 file) and is also giving me some bad time.
rownyr
Re: Raspberry Pi will not play AVC L4.1 file
Fri Jul 12, 2013 7:44 pm
Try stripping the audio streams out, so only the video stream will remain. Then try again. If it works you'll know that at least video decoding is working properly.
Return to “Media centres”
