kavi96
Raspbian or raspbmc?
Sat Feb 02, 2013 11:25 am
If I want to have LXDE, XBMC and RetroPie running on my Raspberry Pi, is it easier/better to put raspbian on the SD and install XBMC or start with raspbmc and install LXDE? Is there much of a difference in performance between the two?
Also, what is the best way to install XBMC on raspbian? I assume you can just do "apt-get install lxde" to install lxde on raspbmc.
Spid
Re: Raspbian or raspbmc?
Sat Feb 02, 2013 11:40 am
kavi96 wrote:If I want to have LXDE, XBMC and RetroPie running on my Raspberry Pi, is it easier/better to put raspbian on the SD and install XBMC or start with raspbmc and install LXDE? Is there much of a difference in performance between the two?
Maybe Berryboot would suffice ?
http://www.berryterminal.com/doku.php/berryboot
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
Return to “Media centres”
