I've successfully got openelec and xbmc installed on a flash running great, Airplay video streaming works perfect when connected via Ethernet. Now I need to move my media Pi to another room so I need to setup my usb wifi adapter.
I have a TRENDnet 300 Mbps Dual Band Wireless N USB 2.0 Adapter TEW-664UB
How do I setup this adapter via Openelc Xbmc?
Re: OpenElec XBMC Wifi Help
Yes I have the same problem. I have aSD card and the media center preinstaled from the PI hut including a WIFI dongel.
But I can not Quit the media center, I can not find a exit and the wifi dongel is not working. How can I go back to the bsic unix screen concole
Thanks for helping
Thanks for helping
I will take a look tonight, just need to setup an SD Card with OpenElec,
You should be able to SSH into the Raspberry Pi with PuTTY (On Windows)
- Contact: Website
What version of OpenELEC are you running? The latest version has easy configuration of Wifi from the "Programs" tab. You don't even need a keyboard (handy if you don't have a hub).
It is mentioned that you can perhaps ssh in and change things. With openELEC that's less likely because it really is a minimal build. You can still SSH in to it but as a design decision, almost anything that can let you modify the system has been removed. If you want to tinker, then Xbian, or Raspbmc would be a better bet.
/Dextrus
/Dextrus
Have more FUN with your Pi. Visit www.pi-fun.com
