Squeezelite Sound Problems
Posted: Wed Jan 23, 2013 9:44 am
I have an issue where after a time ( usually 24 hours as I go to work!) where I start using squeezelite the sound seems like it is not sampling properly. I reboot the server ( not re-start the squeezelite deamon as that has no effect) and all returns to normal - any thoughts - I have seen something about this in the forum but can't find it now. When I use it there is no problems apart from Spotify not working ( but that is the version of LMS on my NAS)
So what happens is:
I have latest version of squeezeplug running. The LMS is on my NAS (excito bubba) . Although I have the server running on the PI I do not use it. It is connected to the amplifier by a DAC which itself uses wifi to connect to the USB portion. The USB stick is in the PI and transmits WiFi/Bluetooth ( not sure which) to the DAC unit which is where the amp is. I turn off the amp ( valve one) and the DAC when not using it. I leave on the Raspberry PI. The NAS is left on all the time.
So what happens is:
