Anyone interested in xbmc git .debs ?
Posted: Tue Jan 22, 2013 9:28 am
by drgr33n
Hey guys I've spend a few days working through the missing dependencies and various fixes to make xbmc compile from git. Finally got there :D Anyway just finished packing up some test packages. Would anyone be interested in trying them ?
The packages are built from the latest git.
Patched with select patches from xbian & raspbmc.
Built with the latest version of rasbian. taglib, libcec and libdvdcss, jdk etc. (.deb's included).
Added projectm (not sure if this works. I think raspbmc removed it due to it being to labor intensive.)
Configured as follows ..
./configure --prefix=/usr --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf --enable-libusb enable-gles --disable-sdl --disable-x11 --disable-xrandr --disable-openmax --enable-optical-drive --enable-libbluray --enable-dvdcss --disable-joystick--enable-libafpclient --disable-debug --disable-crystalhd --disable-vtbdecoder --disable-vaapi --disable-vdpau --enable-pulse  --with-platform=raspberry-pi --enable-optimizations --enable-libcec --enable-player=omxplayer -C
Output of configure
projectm
  XScreenSaver support      :  no
  PNG image support         :  yes
  OGG Vorbis sound support  :  no
  Enabled screensavers:
  - Cyclone                 :  no
  - Euphoria                :  yes
  - Field Lines             :  no
  - Flocks                  :  no
  - Flux                    :  no
  - Helios                  :  no
  - Hyperspace              :  no
  - Lattice                 :  no
  - Plasma                  :  yes
  - Skyrocket               :  no
  - Solar Winds             :  yes
xbmc
  XBMC Configuration:
  Debugging:	No
  Profiling:	No
  Optimization:	Yes
  SWIG Available:	Yes
  JRE Available:	Yes
  Doxygen Available:	Yes
  Crosscomp.:	No
  target ARCH:	arm
  target CPU:	arm1176jzf-s
  OpenGL:	Yes
  ALSA:		No
  DBUS:		Yes
  VDPAU:	No
  VAAPI:	No
  CrystalHD:	No
  VDADecoder:	No
  VTBDecoder:	No
  OpenMax:	No
  Joystick:	No
  XRandR:	No
  GOOM:		No
  RSXS:		Yes
  ProjectM:	Yes
  Skin Touched:	No
  X11:		No
  Bluray:	Yes
  TexturePacker:Yes
  MID Support:	No
  ccache:	Yes
  ALSA Support:	No
  PulseAudio:	Yes
  HAL Support:	Yes
  DVDCSS:	Yes
  Google Test Framework Configured:	No
  Avahi:	Yes
  Non-free:	Yes
  ASAP Codec:	No
  MySQL:	Yes
  Webserver:	Yes
  libssh support:	Yes
  libRTMP support:	Yes
  libsmbclient support:	Yes
  libnfs client support:Yes
  libafpclient support:	Yes
  AirPlay support:	Yes
  AirTunes support:	Yes
  UPnP support:		Yes
  Optical drive:	Yes
  libudev support:	Yes
  libusb support:	No
  libcec support:	Yes
  libcec RPi support:	Yes
  libmp3lame support:	Yes
  libvorbisenc support:	Yes
  libcap support:	Yes
  additional players:	Yes
  External FFmpeg:	No
  PVR add-ons:		No
  prefix:	/usr
atm they are just packed up with checkinstall. Mail me for source.
I'll upload them and add links here at some point today. I'm not 100% sure on what dependencies you will need to make this work as I put so many on to get it to compile I need to go through my history and find everything needed. I'm 99% sure it's just the usual.
Re: Anyone interested in xbmc git .debs ?
Posted: Tue Jan 22, 2013 10:41 pm
by drgr33n
Here are the links as promised. Sorry it took so long I had to fix a couple of things for it to play nice with checkinstall.
libcec_2.0.0-1_armhf.deb
libdvdcss_1.2.11-1_armhf.deb
taglib_20130122-1_armhf.deb
xbmc_12.0-rc3-1_armhf.deb
xbmc binaries are located @ /opt/xbmc-bcm/xbmc-bin/bin.
Posted: Wed Jan 23, 2013 1:35 am
by drgr33n
Sorry can't edit posts. Dependencies are ..
sudo apt-get update;apt-get install fbset mesa-utils ttf-liberation x11-utils python-qt3 samba-common-bin upower libssh-4
start with
/opt/xbmc-bcm/xbmc-bin/bin/xbmc --standalone --no-check
Enjoy.
Posted: Thu Jan 24, 2013 4:19 pm
by charliesroot
I am.
So taking a fresh raspian image, update it to the latest version, update firmware, install depedencies and download and install from git should get me a working XBMC?
Got a spare Pi and a 8 GB card so will try and install. Will it be possible (in the near future?) to update XBMC just by using the apt-get update/upgrade route?
Cheers,
Posted: Thu Jan 24, 2013 6:38 pm
by drgr33n
Moved this over to the raspbian section of this forum. Could I ask a moderator to delete thanks.
@ charliesroot
I wasn't planning to create a repository for these as there seem to be a lot of guys working on xbmc for native support for raspbian. For now I'll just update the links here, but if many people like them I can tidy them up and host a repository. I created these packages so I could select patches from all over the ether and have a nice stable, fast build on my media center.
But yes you can download my packages, install them and away you go.
Here's a link to the new thread.
http://www.raspberrypi.org/phpBB3/viewt ... 66&t=30789
