Page 22 of 22
Re: SqueezePlug Version 6 available
Posted: Tue Dec 24, 2013 2:35 pm
by truehl
I have some time over Xmas, I hope!
I'm already working on a new version but having some trouble with SqueezeLite. I'll inform you! I hope I get a version at the end of 2013 or the beginning of 2014.
Meantime I'm checking out a few things like the Community Squeeze Operating System. I've got a wandboard and I'm testing with it! I think it's far too expensive to be an alternative to the Pi. And the SW, I'm not sure, but it seems very inflexible to me!
Merry Xmas
Posted: Tue Dec 24, 2013 4:28 pm
by danfzx14
That is super!!! Much thanks in advance. :D
Enjoy your holidays
Posted: Wed Dec 25, 2013 8:24 pm
by nejo
Hi, I would also appreciate a version of SqueezePlug that's compatible with my RasPi, very much!
Keep up the great work!
Mono-only?
Posted: Thu Dec 26, 2013 4:55 pm
by fuzzybee
I'm using the 3.5mm stereo output of my RPi for audio. I was listening to sold older music today through Pandora, and realized I was missing some of the audio. I switched to local music, and put on my defacto stereo trrack - Another Brick in the Wall (Part 3) from Pink Floyd's "The Wall". Sure enough, all of the gunshots at the beginning track were coming out of both speakers equally, rather than panning left to right. I searched a little bit, and found that amixer returns
  Playback channels: Mono
  Limits: Playback -10239 - 400
  Mono: Playback 400 [100%] [4.00dB] [on]
Is this due to coding, or hardware? If it's due to hardware, would a USB DAC fix the problem. If it's coding, are there any configuration settings I can change? Thanks!
Posted: Thu Jan 02, 2014 9:50 pm
by danfzx14
Hi Thomas,
I was wondering if you have had any progress in updating Squeezeplug?
Thanks!!
Posted: Fri Jan 03, 2014 8:07 am
by truehl
Hi folks,
yes, I'm making good progress with version 7 of SqueezePlug. It will take some time to finish, because I'll renew SqueezePlug from scratch. I'll remove a lot of unnecessary things, add some new, and refurbish all old functions. SqueezePlug shall become easier and some old bugs will be removed.
The new version will be based on the latest Rassbian Image which gives us some advantages. It will be possible (and it will be the default) to install the latest LMS version, which runs without patches on the HF version of Wheezey.
I like to produce a hopeful bug free version (as far as possible) so it takes a while. Right now I can't tell You a release date, but I hope to give some news soon!
Please be patient,
Thomas
Posted: Fri Jan 03, 2014 2:07 pm
by danfzx14
Thank You Thomas. Your update is appreciated. :D
Posted: Sat Jan 04, 2014 12:03 pm
by mkkyah
Hi Thomas,
It's nice to know you are working on Squeezeplug 7.
Will you integrate Squeezelite with wma support to v7? Picoreplayer did it successfully. I don't know if it's possible with Local Player plugin; maybe Squeezelite should be installed again from Squeezeplug menu separately if that feature is needed.
Posted: Wed Jan 08, 2014 9:27 pm
by truehl
I like to inform you that SqueezePlug 7 is almost ready. Right now I'm doing some final tests. I'm pretty sure I'll be ready the next days. It should be ready this weekend!
Greetings,
Thomas
Posted: Thu Jan 09, 2014 2:53 am
by castalla
truehl wrote:Hi,
Greetings,
Thomas
I'm sure there are a whole lot of squeezeplug fans out there who really appreciate your work and dedication on this!
Thanks in advance.
Posted: Thu Jan 09, 2014 8:45 pm
by badatruc
I'm french so I use the google translator to write you . Sorry for the imperfection of some translation ... :oops:
Squeezeplug I use it for two months to play my music with the LMS control via SqueezePad . I have a subscription to Qobuz (streaming music) , and I installed the plugin developed by Qobuz pierrepoulpe ( http://forums.slimdevices.com/showthrea ... ing-plugin ) for LMS .
I now cover a music server for a very modest budget and this is thanks to you and pierrepoulpe . :D
I wanted to f├ęciliter for the quality of your tutorial that helped me, so I do not know linux, do the installation with ease . Congratulations! I must take five minutes to get done to you two a gift for your excelent work!
This now I want to use the server to read Towky my videos but I do not know how this intallation because since I arrived a few days longer enter the setup squeezeplug .
I use PUTTY and once I entered the username and password, I entered '' setup '' but nothing happens !
Do you have a solution for this problem ?
Thank you again!
Posted: Thu Jan 09, 2014 10:22 pm
by truehl
badatruc wrote:Hello,
Thank you again!
Please try to enlarge the putty window!
Posted: Thu Jan 09, 2014 10:25 pm
by truehl
mkkyah wrote:Hi Thomas,
In SqueezePlug 7 version 1.4 of SqueezeLite will be integrated. Here the part of the release notes of SqueezeLite 1.4:
Version 1.4 also includes support for wma and alac decode via the ffmpeg library if it is built with the -DFFMPEG build option. (This is not included in binaries by default).
Thomas
SqueezePlug Version 7 available
Posted: Fri Jan 10, 2014 7:53 am
by truehl
Hi Folks.
SqueezePlug Version 7 is available!
Please visit the new post: http://www.raspberrypi.org/forum/viewto ... 77#p484277
Posted: Sat Jan 11, 2014 10:16 am
by mkkyah
Thomas
Ralphy from Slimdevices Forums is building Squeezelite with that feautures for Rpi and shares for picoreplayer updates. I'm sure he would share for Squeezeplug, too.
Thanks again for v7; I will try it today for a friend.
Posted: Sat Jan 11, 2014 10:24 am
by truehl
Thomas
I thought this feature is now integrated in the official SqueezeLite 1.4 version. If this is not the case I surely will integrate Ralphys version! Ralphy is a good friend of mine so it's no problem at all. Can someone please tell us the status quo?
Thomas
Posted: Sat Jan 11, 2014 10:27 am
by truehl
Please turn over to the SqueezePlug version 7 thread! Thanks a lot!
Thomas
