busywait
Command line tool to edit .flac file metadata?
Tue May 26, 2020 2:53 pm
I'd like to make a bulk correction to a folder of music files (.flac in this case). The .flac files were created with dBPowerAmp on Windows.
I've found out that id3v2 and mid3vs won't work with .flac files and that the FLAC format uses Ogg Vorbis comments. So
sudo apt install vorbis-tools
When I try to use vorbiscomment I also get an error:
pi@raspi3b: vorbiscomment -l WrongAlbumTagValue.flac
Failed to open file as Vorbis: Input is not an Ogg bitstream.
Does anyone here have any command line suggestions to amend the value of the "Album" field of some .flac files (without changing the other carefully added metadata)?
bls
Contact: Twitter
Re: Command line tool to edit .flac file metadata?
Tue May 26, 2020 3:38 pm
Haven't looked at these in detail, but a quick review of the results for sudo apt search flac shows some promising candidates worth your investigation: flac, flactag, lltag, pacpl, and puddletag.
Pi tools:
Easily and quickly build customized-just-for-you SD Cards: https://github.com/gitbls/sdm
Free your network from your router's DHCP/DNS:https://github.com/gitbls/ndm
Easy strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
scruss
Tue May 26, 2020 4:19 pm
metaflac from the flac package is what I use for mass tagging live shows for the Internet Archive:
sudo apt install flac
It's a big clunky: you'll end up with lots of --set-tag="NAME=VALUE" in the call. ISTR that Vorbis tags can be free-form, but the one you likely want is --set-tag="ALBUM=...".
metaflac --list is also almost entirely useless, as it lists all metadata. Got embedded artwork? It lists that, line by line, in hex.
Pronouns: he/him
busywait
Tue May 26, 2020 7:17 pm
metaflac ...
Thanks... if it's known working, I'll take a look :)
Wow, --list certainly doesn't try to have a sensible default! It took me a while to work this out...
metaflac --list --block-type=VORBIS_COMMENT file.flac
And then, remembering to *remove* Album before re-adding it
pi@raspi3b:~  $ metaflac --remove-tag="Album" --set-tag="Album=New Name" --preserve-modtime *.flac
for the win :)
busywait
Tue May 26, 2020 7:18 pm
Thanks - I'm new to apt, I keep forgetting that it might be able to help me!
scruss
Tue May 26, 2020 9:37 pm
Huh. I didn't think you needed to do that. All the software I've used just uses the newest ALBUM comment tag and ignores the rest.
Pronouns: he/him
Return to “Media centres”
