How to turn your Raspberry Pi into a media center
Posted: Mon Mar 16, 2020 6:06 am
by KodiMaster
If you want to exploit your Raspberry Pi, one of the recommended options is to turn it into a media center.
The best media center for it is Kodi which can be used for watching high-quality movies and TV shows.
There are two options for installing Linux distributions for Kodi: LibreELEC and OSMC
Here is a tutorial explaining how to install those two distributions on Raspbarry Pi: https://kodibeginner.com/install-kodi-raspberry-pi/
Re: How to turn your Raspberry Pi into a media center
Posted: Thu Mar 26, 2020 3:02 am
by NystriX
Can the Zero W run it?
Posted: Thu Mar 26, 2020 1:08 pm
by snowballEarth
Yes, the Pi Zero W will run Kodi (LibreElec) quite well. Just make sure to use a good quality microsd card like Sandisk Ultra.
The only possible problem is that there is no wired ethernet with the Pi Zero W, so the wifi reception to it has to be strong enough to prevent video stuttering.
