tb-killa
USB DVB-S2 Card
Sun Dec 23, 2012 9:22 pm
this is my first post,
I'm currently working on making my RPi to be a DVB-S2 Media Center.
My configuration :
RPI with latest RaspBMC (nightly with PVR)
USB TechnoTrend S2-3600 Card connected to active USB Hub
The Card has also external Power for LNB too.
I managed to get tvheadend configurate and backend work:
- Scan is OK
- Signal is OK
If i start playing TV Stream inside XBMC (Frontend) i have some faults:
- TV Streams has a lot of artefacts & most of time there is no sound at all.
What i will test next days would be the integration of MPEG2 Lizenz, maybe SD Quality Channels could work.
What i also test is overclocking the RPI with Foce Turbo Mode 1 and also manually with some different configs.
But the same problem results !
Model B 512MB / Technotrend TT-connect S2-3600
richardp
Re: USB DVB-S2 Card
Sun Dec 30, 2012 9:59 am
tb-killa wrote:Hi,
My configuration :
- Scan is OK
- Signal is OK
Have you looked for USB errors while running a stream? dmesg (or tail -f /var/log/messages while running) should show something
Try recording a 30 second stream and check to see if the video/audio is intact using another PC... If not, then dive in to the USB aspects to see if all the data is sane.
R
RaspberryPi's galore
Solid run CuBox
ODroid U2
richardp
Re: USB DVB-S2 Card
Sun Dec 30, 2012 10:58 am
I have verified using a WinTV Nova DVB-T stick and mumudvb(in the repo) and I am able to stream all the channels on a transponder without problems.
Richard
[Addendum]
start with normal DVB-S channels.. DVB-S2 channels are very high bandwidth and do not work too well over Wifi.
Solid run CuBox
ODroid U2
tb-killa
Re: USB DVB-S2 Card
Mon Jan 07, 2013 10:23 pm
richardp wrote: Have you looked for USB errors while running a stream? dmesg (or tail -f /var/log/messages while running) should show something
R
Hello ... i test it again and check with dmesg if got heavy Errors:
Here ist the dmesg log after Boot: http://pastebin.com/Jb1kwmMu
And here are the Errors if Tuning:
pctv452e: I2C error -121; AA 60  CC 00 01 -> 55 60  CC 00 00.
pctv452e: I2C error -121; AA 7C  CC 00 01 -> 55 7C  CC 00 00.
pctv452e: I2C error -121; AA 73  CC 00 01 -> 55 73  CC 00 00.
pctv452e: I2C error -121; AA 8A  CC 00 01 -> 55 8A  CC 00 00.
pctv452e: I2C error -121; AA A6  CC 00 01 -> 55 A6  CC 00 00.
pctv452e: I2C error -121; AA A9  CC 00 01 -> 55 A9  CC 00 00.
pctv452e: I2C error -121; AA C1  CC 00 01 -> 55 C1  CC 00 00.
pctv452e: I2C error -121; AA DD  CC 00 01 -> 55 DD  CC 00 00.
pctv452e: I2C error -121; AA 69  CC 00 01 -> 55 69  CC 00 00.
pctv452e: I2C error -121; AA 80  CC 00 01 -> 55 80  CC 00 00.
pctv452e: I2C error -121; AA 9C  CC 00 01 -> 55 9C  CC 00 00.
pctv452e: I2C error -121; AA B4  CC 00 01 -> 55 B4  CC 00 00.
pctv452e: I2C error -121; AA CB  CC 00 01 -> 55 CB  CC 00 00.
pctv452e: I2C error -121; AA E7  CC 00 01 -> 55 E7  CC 00 00.
pctv452e: I2C error -121; AA 12  CC 00 01 -> 55 12  CC 00 00.
pctv452e: I2C error -121; AA 2A  CC 00 01 -> 55 2A  CC 00 00.
pctv452e: I2C error -121; AA 46  CC 00 01 -> 55 46  CC 00 00.
pctv452e: I2C error -121; AA D9  CC 00 01 -> 55 D9  CC 00 00.
pctv452e: I2C error -121; AA F0  CC 00 01 -> 55 F0  CC 00 00.
pctv452e: I2C error -121; AA 0C  CC 00 01 -> 55 0C  CC 00 00.
pctv452e: I2C error -121; AA BC  CC 00 01 -> 55 BC  CC 00 00.
pctv452e: I2C error -121; AA D3  CC 00 01 -> 55 D3  CC 00 00.
pctv452e: I2C error -121; AA EF  CC 00 01 -> 55 EF  CC 00 00.
pctv452e: I2C error -121; AA EE  CC 00 01 -> 55 EE  CC 00 00.
pctv452e: I2C error -121; AA 06  CC 00 01 -> 55 06  CC 00 00.
pctv452e: I2C error -121; AA 21  CC 00 01 -> 55 21  CC 00 00.
pctv452e: I2C error -121; AA 29  CC 00 01 -> 55 29  CC 00 00.
pctv452e: I2C error -121; AA 40  CC 00 01 -> 55 40  CC 00 00.
pctv452e: I2C error -121; AA 5C  CC 00 01 -> 55 5C  CC 00 00.
pctv452e: I2C error -121; AA 9A  CC 00 01 -> 55 9A  CC 00 00.
pctv452e: I2C error -121; AA B1  CC 00 01 -> 55 B1  CC 00 00.
pctv452e: I2C error -121; AA CD  CC 00 01 -> 55 CD  CC 00 00.
pctv452e: I2C error -121; AA 1A  CC 00 01 -> 55 1A  CC 00 00.
pctv452e: I2C error -121; AA 31  CC 00 01 -> 55 31  CC 00 00.
pctv452e: I2C error -121; AA 4D  CC 00 01 -> 55 4D  CC 00 00.
Seems to be some Driver Issue but at BootUp the Raspberry know the USB Sat Device with Name.
Chol
Re: USB DVB-S2 Card
Sat Jan 19, 2013 12:50 pm
I've got the same DVB-S2 adapter, SD channels work but HD channels are stuttering - even if I decode them on a different machine.
The I2C error is a known problem of the driver, which also occurs on non-Raspberry machines: http://www.linuxtv.org/pipermail/linux- ... 32911.html
Return to “Media centres”
