mihailolja
TVHeadend won't record onto attached SSD Drive.
Wed Nov 13, 2019 10:08 am
My Pi 4 recognises the 240 GB SSD drive fine and mounts it automatically to /media/pi/ef etc....
TV Headend records fine but places the recording on the sd card under /media/pi/Storage/Recordings
Screenshot 2019-11-13 at 10.07.51.png (151.48 KiB) Viewed 2956 times
despite me having changed the default location for recordings as per the screenshots below. What am I missing?
Thanks in advance.
Mihailo
Screenshot 2019-11-13 at 10.02.24.png (49.09 KiB) Viewed 2956 times
diogen151
Re: TVHeadend won't record onto attached SSD Drive.
Wed Nov 13, 2019 10:23 am
Mihailo, check that you have rw permissions at: /media/pi/efd****
ls -al /media/pi
comments >/dev/null ;-)
mihailolja
Wed Nov 13, 2019 10:26 am
Thought it might come to that. Thanks, will check.
mihailolja
Wed Nov 13, 2019 8:06 pm
No luck, I've run chmod 777 against the directory /media/pi/ef*** but it's still putting recordings in /media/pi/Storage/Recordings?
Any ideas?
Mihailo
diogen151
Wed Nov 13, 2019 8:56 pm
I've recently tried with /mnt/nfs , this is NFS (network) share and recording (T2, HEVC) went OK.
Maybe it is 4b USB issue, do you have something in logs:
sudo dmesg -T
I had problem with SSD connecting-reconnecting to OS.
Cob
Wed Nov 13, 2019 11:13 pm
No problems here with the usb hard drive manually mounted in /mnt/ via fstab on my Pi4.
Have you tried creating a ‘recordings’ folder in your hard drive and pointing TVHeadend towards that rather than the root of the hard drive ?
Are you using an up-to-date version of TVHeadend?
mihailolja
Thu Nov 14, 2019 9:59 am
Thanks Cob, will try that.
Cob
Thu Nov 14, 2019 11:54 am
Remember to assign correct permissions to the folder.
mihailolja
Thu Nov 14, 2019 10:48 pm
Still no luck. Am using HTS Tvheadend 4.2.8-34~g24a2f59e9 and have run chmod 777 against the Storage/Recordings directory I have created for myself under /media/pi/ef*****/Storage/Recordings. Tried to record something via LibreElec and it still goes on the SD card.
Does TVheadend have another setting somewhere which sets the recording location? :|
For the record I can create files on the SSD under the Recordings directory no problem. Also did a DMESG and no issues with the SSD appeared.
Cob
Fri Nov 15, 2019 1:44 am
Odd if permissions are all set correctly.
Could try updating to 4.2.8.36 to see if it helps https://cloud.disroot.org/s/y3YtbkrgFodCwdH
Or try the ‘unstable’ 4.3 build (I been running it without any issues).
snowballEarth
Fri Nov 15, 2019 3:07 pm
What file system is your ssd?
In my experience tvheadend prefers recording to linux formatted, ext4 drives rather than ntfs or fat.
Changing it solved similar prolem in past
Roken
Fri Nov 15, 2019 9:10 pm
Using mounting via fstab, try:
sudo chown pi /mnt/mountpoint
replace /mnt/mountpoint with your actual mount directory.
Then remount
sudo mount -a
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
mihailolja
Tue Nov 19, 2019 5:08 pm
Sigh....beginning to lose faith here.
Have upgraded tvheadend to 4.2.8.36 unfortunately no difference. (Where can I get the 4.3 file?)
Have manually unmounted and remounted my ssd drive to /media/pi/newmount instead of the default, also no difference.
File system on the SSD is ext4.
Not sure what to try next?
diogen151
Tue Nov 19, 2019 9:47 pm
Maybe silly idea, why not try with ext4 formatted ordinary USB stick with proper rwx permissions ?
Just like proof of concept ?
Cob
Tue Nov 19, 2019 10:54 pm
The latest v4.3 build is available from https://cloud.disroot.org/s/y3YtbkrgFodCwdH
snowballEarth
Wed Nov 20, 2019 11:58 pm
Did you save (or click apply) in tvheadend interface after adding the new recordings destination?
Does this match exactly the mount point name?
Can you mount the ssd to a simple, short folder name and see if that works? The ef*** folder name length and hyphens may be throwing it. Then set permissions.
mihailolja
Mon Nov 25, 2019 11:06 am
I think I've resolved this and it did boil down to permissions in the end.
First of all a big thanks to everyone that has helped, much appreciated! Roken, cob, diogen151, snowballEarth.
So I read on the tvheadend forum that ALL directories need the right permissions not just the final target ef*** directory. So I changed them for /media and then for /pi too. Tested on tvheadend by recording something and it put it on the SSD drive, under ef***. :D
Will test from LibreElec later....
mihailolja
Tue Nov 26, 2019 9:42 am
Spoke to soon!!!!
Recording directly from tvheadend is fine it puts the recording on the SSD drive.
Recording from LibreElec still stubbornly puts it on the SD card.
Also have another issue in that I get PVR is starting...0% in LibreElec, quite serious errors in the Kodi log:
2019-11-26 07:31:08.569 T:2875597680 DEBUG: Create: Creating PVR add-on instance 'Tvheadend HTSP Client'
2019-11-26 07:31:08.586 T:2875597680 INFO: AddOnLog: Tvheadend HTSP Client: pvr.hts - starting PVR client
2019-11-26 07:39:25.743 T:3011164640 DEBUG: ------ Window Init (MyPVRGuide.xml) ------
2019-11-26 07:39:25.743 T:3011164640 INFO: Loading skin file: MyPVRGuide.xml, load type: KEEP_IN_MEMORY
2019-11-26 07:39:28.476 T:3011164640 DEBUG: ------ Window Deinit (MyPVRGuide.xml) ------
2019-11-26 07:39:36.090 T:3011164640 DEBUG: Destroy: Destroying PVR add-on instance ':192.168.1.74:9982'
streamer1122
Tue Nov 26, 2019 8:19 pm
If I were feeling lazy, I'd symlink over the location. So...
ln -s /media/pi/ef... /media/pi/Storage/Recordings
Remember: repoint the recording path in the tvheadend interface though
Did you create a tvheadend user? Has this been configured in libreelec? Is this the same user as the user you're logging into tvheadend:9981 as?
rpdom
Wed Nov 27, 2019 7:55 am
I just mounted my external SSD in the location that tvheadend was using. Simples :)
Unreadable squiggle
mihailolja
Thu Nov 28, 2019 10:12 am
My problems have gone beyond the original one of LibreElec not recording onto the SSD drive.
LibreElec now no longer has any TVHeadend add-ons, they've all disappeared!
Have also logged a query on the LibreElec forum to see if anyone can help.
One problem after another.......and all I wanted to do was to save myself buying a new PVR recorder. Looks like I might have to do that after all. :cry:
mihailolja
Thu Nov 28, 2019 10:39 am
So upgraded to LibreElec 9.2 and add-ons have returned.
The saga continues! :D
mihailolja
Fri Nov 29, 2019 2:35 pm
I now get error 403:Forbidden when trying to access Tvheadend from a browser. This is the output from systemctl status tvheadend:
https://pastebin.com/RSDygNn1
cpc464
Tue Dec 03, 2019 7:11 pm
Hi
About the recording path, somebody mentioned linking it from the default . It is a good idea to do this anyway, so that in the future, if you change the disk, you can just re-create the link instead of having to alter the TVH/Libelec configuration. A new disk will likely mount itself under /media/<user name>/<disk-label> or similar. Or you could hard wire it in /etc/fstab. Creating the link gets round all of that.
Jim
Unix engineer since 1989
mihailolja
Wed Dec 04, 2019 11:37 am
Hi
Jim
Thanks Jim, I've given up with LibreElec and a Pi4. Am now trying OSMC and a Pi3. There is a blog here where someone has got it to work:
http://unixetc.co.uk/2019/11/22/how-to- ... pberry-pi/
Return to “Media centres”
