No signal to Pi 3+ with TV aerial splitter but ok with aerial cable direct?
Posted: Mon Sep 16, 2019 12:58 pm
by mihailolja
I'm having all sorts of problems with my Pi 3+ and tv headend device.
My main issue is when I connect the tv aerial directly to the Pi all seems okish (the same cable goes to my Samsung freeview tv and its perfectly fine there).
However when I put the cable into a splitter so that the signal goes to my tv and to my Pi I either get no services on the Pi or no muxes. Is the splitter at fault or do I need something else so that I can continue to use my Samsung tv and play with my Pi?
Any help appreciated.
Mihailo
Re: No signal to Pi 3+ with TV aerial splitter but ok with aerial cable direct?
Posted: Mon Sep 16, 2019 1:07 pm
by drgeoff
Can we have a close-up picture of the splitter that shows what is written on the label?
Posted: Mon Sep 16, 2019 1:15 pm
by pcmanbob
Are you sure you have a splitter connected correctly, they are often market showing which port is input ( aerial ) , incorrectly connecting them may lead to the signal not being passed through.
Looking at your image I can't see the markings but comparing it with this image
I would say you have it connected wrong, assuming the black wire is the aerial cable
Posted: Mon Sep 16, 2019 1:19 pm
by RaTTuS
^THIS
Posted: Mon Sep 16, 2019 1:34 pm
by mihailolja
Not much on it really but here it is...
Posted: Mon Sep 16, 2019 1:38 pm
by pcmanbob
As I said aerial needs connecting to the one marked IN.
Posted: Mon Sep 16, 2019 1:48 pm
by mihailolja
Surely the IN connector goes to the TV? Leaving one of the other connectors for the incoming aerial cable and the other for the Pi?
Or have I lost the plot here!?
Thanks for your patience.
Mihailo
Posted: Mon Sep 16, 2019 1:49 pm
by trejan
Signal from the antenna goes to IN and then splits into the two OUTs for the TV and Pi...
Posted: Mon Sep 16, 2019 1:52 pm
by pcmanbob
^ What he said........
IN to splitter out to TV, hence aerial to IN TV's to OUT....................................
Posted: Mon Sep 16, 2019 1:54 pm
by mihailolja
Great, thanks so much.
That's brilliant.
Mihailo
Posted: Mon Sep 16, 2019 2:44 pm
by drgeoff
With the 3 resistor type splitters all 3 ports are exactly the same. The lower loss type using RF transformer do have a specific input port.
Posted: Wed Sep 25, 2019 9:23 am
by mihailolja
Just for the record I have had to buy a cheap female to female coupler to get my aerial cable to connect to the splitter.
Thanks for the help again!
