Hi
i am very happy to see that Pi 4 has two hdmi output.
Does it actually mean , we can use two different videos (left and right view for 3D) and play it in perfect sync?
Or one full sidebyside video (3840x1080 or 2560x720) and playback to the extended display? Is it possible?
If somebody could test it for me i can upload such files.
Many thanks
Re: Dual output for 3D stereo projection?
Somebody could check it for me?
Sure, do you know what software can do this?
I got Openkinect to compile, but no luck yet with VRui
https://arsandbox.ucdavis.edu/technical ... s/vrui-vr/
I'm dancing on Rainbows.
I dont know the software, thats why i ask here
You might have to do a google.
I found a -stereo option for glxgears
http://linuxcommandlibrary.com/man/glxgears.html
This looks interesting
https://hub.packtpub.com/rendering-ster ... ng-opengl/
https://www.mesa3d.org/intro.html
I did not have much trouble with compiling the demo examples.
https://www.mesa3d.org/repository.html
I noticed these stereo versions in the examples, but that was before I had a Pi4
http://www.gali-3d.com/archive/articles ... torial.php
Glut code works, if you install the newer freeglut lib.
I would say it will work but it just needs someone to prove it
Another option is use a VR app for a smart phone, cheap VR glasses and let the Pi4 serve the images over WiFi.
Dual 4K glasses with two HDMI inputs? Probably expensive?
Thanks for the link.
I dont want to use a VR headset, i have a dual projector rig for 3D.
So what i only want is to playback two 1920x1080 (left-right) OR one SidebySide 3840x1080 OR at least 2560x720 video in frame perfect sync.
One video for one hdmi out, the other on the 2nd hdmi.
Wifi is not good here..
thanks
thanks
Are you using shutter glasses?
I have programmed the General purpose clock output 0 on the older Pi's GPIO.
If you use the HDMI clock as the source input, it might divide down and sync.
With 4K the best will be 30Hz? That might be noticeable.
You might have to wait for the new BCM2711 peripheral manual to figure out which registers.
Clues might already be in the device tree overlay sources.
Pi4's have been out now for a few months, some might have made it into the Uni media labs.
Might be too early for the papers to be written up?
Everyone will probably be doing it next year?
No, i use passive glasses with a silverscreen.
What displays do you hope to output to? How will you view them as stereo?relaxpi4 wrote: ↑Tue Sep 10, 2019 1:28 pmHi
Many thanks
AFAIK most 3D displays use a single input port for both eye views, which takes care of synchronisation.
To get good stereo effect on a large screen I suspect you need to go for per-eye filters such as those used with 3dTVs because you probably can't get the optics to work like a headset with one screen for each eye.
Eye convergence is an important factor and two big screens, one per eye, would require the eyes to diverge a lot.
I see your later post mentions dual projectors. How do you get 3D from that? Are they projecting to separate screens? Can you match the view to the users inter-pupillary distance and get the eyes to converge at the centre of each screen? Have you tried this with still images?
ETA is this a polarised system? Two projectors onto the one screen, one through H-polariser the other through V-polariser? If you can match projection geometry between them so that everything lines up that could work I suppose.
I make passive 3D projections since 10 years with dual projectors, polar filters, etc. No problem here, just like in cinemas.
But i like to playback from a Pi4 instead of PC if possible
Had a look at VLC, it can do 3D
https://wiki.videolan.org/SoC_2011/Ster ... on_support
But not sure if it can do the polarised output type.
i supposed the source can be modified and recompiled.
Video or computer generated data?
https://escience.aip.de/visualisation/t ... 3d-movies/
This looks very interesting
http://bino3d.org/\
I have starting to "make" it on Gentoo64.
Not sure how long it will take to make or crash
http://bino3d.org/\
Well that was painless.
Let us know if Big Buck Bunny runs in 3D
http://bbb3d.renderfarming.net/download.html
- Attachments
- BinoGentoo64.png (113.09 KiB) Viewed 3393 times
Thanks but VLC seems only good for Nvidia vision and AMD HD3D, while i don't use these.
There is no "polarized output" its called dual screen output in stereoscopic player.
I simply need to put one video to hdmi1, other video to hdmi2 output.
So it's video in my case.
Bino uses OpenGL and has dual/multi screen options.
I will need to try it on my dual screens at work
Might have to have a chat with the media labs guys around the place, this looks useful.
I was looking for VR software, this Bino might do it.
cool, pls check
Purely out of curiosity, do you have a link to examples of contemporary rigs?
I've left the "scene" a long time ago, my FED stereo slide projector is gathering dust (heck even finding a picture of it online is difficult!).
Plan B long term?
https://www.khronos.org/openxr/
This compiled, but I have no idea how to use it yet.
More for AR/VR games than 3D recorded videos?
Now we just need the Pi equivalent of the google cardboard.
A dual HDMI display headset.
Perhaps with an i2c/SPI based motion sensor?
epoch: i dont have a picture near me, but my rig looks like these:
https://www.google.com/search?biw=1920& ... CAc&uact=5
Cool. Thanks!
I had a play with Bino and Stereoscopic Player in Windows.
Lots of options to tinker with, dual and single screen.
Bino should work on the Pi4 if you can compile it.
Someone with two screen working should try it
I so need to make some coloured glasses
Saw a new "White" laser from SDL, projectors will get brighter and last longer.
Bino author wrote to me:
The problem is that Pi doesnt have "real" OpenGL, only OpenGL ES.
Version 4 has real OpenGl?
thanks
thanks
Hey thread. My software info-beamer pi can play videos across two displays on the Pi4, but I observe a vsync interval offset between the two HDMI outputs of up to 8ms. So even the software side seems to push out the frames at the same time, there's might still be a small offset between them. This is noticable for vertical movement and I expect 3D looks crappy that way. This offset seems to be random too: Restarting the software often produces a different offset. It's weird.
I'm not sure if there is a way to sync the HDMI output somehow. So far I'm not sure how that would work.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
cool
if the hdmi outputs are in sync (say 1-2 ms difference), how long remain it in sync?
"Restarting the software often produces a different offset"
So i only have to start a few times, and use the best what i see with my eyes?
"I'm not sure if there is a way to sync the HDMI output somehow. "
Maybe engineers for ex. 6by9 can answer this, if possible.
So far in my very limited tests, the difference seems to stay fixed.
I guess, but that's not something I'm comfortable with. Seems crappy."Restarting the software often produces a different offset"
That would be great indeed. On the Pi3 and before there was a way to influence the HDMI clock rate slightly. This allowed to slowly drift the vsync towards cross-device synced playback. From what I understand this is not supported on the Pi4."I'm not sure if there is a way to sync the HDMI output somehow. "
