PiModules
Re: What are your OVERCLOCKING settings when using XBMC??
Tue Jun 17, 2014 10:04 pm
Hi
what do you mean ?
waferguitars
Thu Jun 19, 2014 3:48 pm
Hi, I'm a noobie, and it will sound like it. I'm using Openelec for stream TV. Is Overclocking better than finding an SD card with a faster RAM speed? Otherwise, how do you know when you have gone too far with overclocking?
dom
Fri Jun 20, 2014 2:55 pm
coolskull007 wrote:just wondering how much does one overvolt setting add?
0.025V. See http://elinux.org/RPiconfig
mascondante
Fri Oct 31, 2014 1:38 am
jamesh wrote:
x7dude wrote:
Why? There a list of various valid OC settings above - do we need any more? You can keep trying settings, best I've heard of is 1.2Ghz, you won't break it, but not everyone will get that far.
Yeah that seems about the limit for me. I occasionally have issues but not often enough to majorly annoy me. This is what I have:
arm_freq=1200
force_turbo=1
core_freq=500
sdram_freq=600
over_voltage=10
I've managed to push the core up to 550 but things start to get a little strange at that point. Do remember that each RPi is slightly different. Also having too much hooked up to the USB ports can cause a pretty major power drain so do be sure to have a powered USB hub and a power adapter rated 2 amps or above. I'm using these products:
http://www.amazon.com/gp/product/B00GC35SF6/
https://www.amazon.com/gp/product/B00DG9D6IK/
joecool2002
Wed Jul 15, 2015 4:27 pm
I use 800mhz over the standards 700.. The change helped a lot, very snappy. Don't forget with over volt, it will shorten the life of your Pi, so I use the second one :)
dom
Wed Jul 15, 2015 5:36 pm
1 unit == 25mV (http://elinux.org/RPiconfig)
ripednail
Tue Jul 21, 2015 10:14 am
Raspberry pi 2 b +
arm_freq=1050
over_voltage=4
core_freq=525
gpu_freq=350
sdram_freq=480
over_voltage_sdram_p=2
over_voltage_sdram_i=2
over_voltage_sdram_c=2
gpu_mem=256
pawlo6506
Fri Mar 11, 2016 8:46 pm
Well i overclocked my rpi 2 to 1ghz
these are my settings and it works very snappy
arm_freq=1000
core_freq=500
sdram_freq=500
over_voltage=4
Return to “Media centres”
