Page 2 of 2
Re: How to install XBMC on Wheezy Raspbian
Posted: Fri May 03, 2013 9:15 am
by fredca
I'm a bit o0f a newbie but have downloaded the package XBMC_Raspi_a4130c1.tgz but how do I install this? apt-get doesn't seem to have a mechanism to point to this file.
Posted: Fri May 03, 2013 10:51 am
by TheQuestor
fredca wrote:I'm a bit o0f a newbie but have downloaded the package XBMC_Raspi_a4130c1.tgz but how do I install this? apt-get doesn't seem to have a mechanism to point to this file.
There is a FAQ section at the top f my site that walks you through it.
tar -zxf XBMC_Raspi_a4130c1.tgz
cd devel
sudo apt-get install libmicrohttpd10 libtinyxml2.6.2 libmysqlclient18 liblzo2-2 libpcrecpp0 libsdl1.2debian libhal1 libhal-storage1 libva1 libva-glx1 libyajl-dev libssh-dev libfribidi-dev
sudo dpkg -I xbmc_112-1_armhf.deb
should fix you right up.
Posted: Fri May 03, 2013 12:09 pm
by fredca
Thanks for the prompt and courteous reply. I'm sorry I didn't see the faq on your home page but having followed your instructions it said it had
Provides: xbmc
Description: Package created with checkinstall 1.6.2
but I can't find the package. In subdir devel typing xbmc results in a "not found" message.
typing
./usr/lib/xbmc/xbmc.bin
which is the only executable I could find I get
./usr/lib/xbmc/xbmc.bin: symbol lookup error: ./usr/lib/xbmc/xbmc.bin: undefined symbol: vc_tv_get_display_state
Posted: Fri May 03, 2013 5:24 pm
by TheQuestor
fredca wrote:Thanks for the prompt and courteous reply. I'm sorry I didn't see the faq on your home page but having followed your instructions it said it had
Provides: xbmc
typing
It appears you have not updated your PI.
sudo apt-get install git-core
sudo wget http://goo.gl/1BOfJ -O /usr/bin/rpi-update && sudo chmod +x /usr/bin/rpi-update
sudo rpi-update
reboot and try again
you may also want to make sure your os up to date
sudo apt-get update
sudo apt-get dist-upgrade
then you should not have any issues
Posted: Fri May 03, 2013 7:50 pm
by thepimonster
Hi
I have found a good guide on how to set up a raspberry pi media center
http://jtech4you.com/how-to-set-up-a-ra ... ia-center/
hope this helps :D
Posted: Sat May 04, 2013 12:09 pm
by fredca
Thanks TheQuestor that is now working. All I need now ist understand how to set up xbmc.
Thepimonster's link should help wit that. So thanks also to thepimonstert
Posted: Sun Jan 05, 2014 11:31 pm
by mundodacana
sudo echo "deb http://archive.mene.za.net/raspbian wheezy contrib" > /etc/apt/sources.list.d/mene.list
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-key 5243CDED
sudo apt-get update
sudo apt-get install xbmc
Worked like a charm for me, very thanks :D
