Casty
Terminal shown when playing video in XBMC
Sat Dec 01, 2012 8:27 pm
I tried searching and could not find a solution online:
Right now I have my Pi running composite video (4:3) with XBMC. When playing a video that is not "zoomed" in, the terminal window is showing in the background behind the video. Is there a way to hide the terminal by either displaying a black background while XBMC is running or hiding the terminal altogether?
Is this normal and working as intended?
Thanks in advance!
ahstwin
Re: Terminal shown when playing video in XBMC
Sun Dec 02, 2012 11:22 am
I've had this problem too. The only workaround I've been able to find for it was to do the following post login:
~$ clear
~$ sudo /usr/lib/xbmc/xbmc.bin
Basically, clear the screen so there's only one line showing when you play your movie. If someone's figured out the real fix please post it here !
redhawk
Sun Dec 02, 2012 11:38 am
Try: clear;sudo /usr/lib/xbmc/xbmc.bin
Richard S.
Casty
Mon Dec 03, 2012 6:19 am
That works pretty well... except the cursor is still there blinking!
I saw this solution, I'd hate to resort to this though: http://raspberrypi.stackexchange.com/qu ... ying-video
I could always have a script to execute that on start-up and shut-down of XBMC I guess.
martk20
Mon Dec 03, 2012 1:11 pm
On a slighty different matter. Is it possible to dynamically split the memory 128/128 on entry to xbmc and revert back to 64/192 on exit of xbmc to Debian?. Going in to xbmc should be no problem. A script to run an elf file should suffice. But I can see no way to change back on exit.
KenMacD
Fri Dec 07, 2012 12:12 am
Try:
sudo setterm -clear >/dev/tty0 && xbmc-standalone
Return to “Media centres”
