cazz
tvheadend and DVB-T does not find TV card
Thu May 30, 2019 9:36 pm
Hi
After some Days trying to connect my TV card to a Linux it now looks like it works with raspberry Pi.
lsusb
Bus 001 Device 004: ID 0b48:3015 TechnoTrend AG
dmesg |egrep "firmware|dvb|frontend|usb"
[    3.641827] usb 1-1.1.2: dvb_usb_v2: found a 'TechnoTrend TT-connect CT2-4650 CI v1.1' in warm state
[    3.642053] usb 1-1.1.2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[    3.642101] dvbdev: DVB: registering new adapter (TechnoTrend TT-connect CT2-4650 CI v1.1)
[    3.642308] usb 1-1.1.2: dvb_usb_v2: MAC address: 81:7f:00:00:00:00
[    3.677276] si2168 3-0064: firmware version: B 4.0.2
[    3.784108] usbcore: registered new interface driver dvb_usb_dvbsky
[    4.234660] usbcore: registered new interface driver brcmfmac
[  313.833528] rpi_firmware_get_throttled: 11 callbacks suppressed
[  353.353653] rpi_firmware_get_throttled: 13 callbacks suppressed
I did follow this guide to install tvheadend
https://www.dirtyoptics.com/raspberry-p ... tvheadend/
and also read this page and copy the three fw files to /lib/firmware
https://www.linuxtv.org/wiki/index.php/ ... T2-4650_CI
and when I run
w_scan -ft -c SE
Info: using DVB adapter auto detection.
main:3916: FATAL: ***** NO USEABLE TERRESTRIAL CARD FOUND. *****
Please check wether dvb driver is loaded and
verify that no dvb application (i.e. vdr) is running.
So it looks like it loading but still is not??
/Cazz
Return to “Media centres”
