Churmenton
Audio from USB Card
Wed May 29, 2019 12:31 pm
Hi there,
I am using a USB speaker to output the audio of Raspberry 3B+. The sound is perfect, but how can I figure out the audio quality which comes from the speaker. For example, I use a music player to play a track whose sample is 192kHz and bit rate is 24bit, how can I know if the output audio quality is as the same as the input source?
Man in a van
Re: Audio from USB Card
Fri May 31, 2019 9:14 am
Try with this command
cat /proc/asound/card1/pcm0p/sub0/hw_params
You will need to find your card number and have the stream playing.
This is my usb card playin fip radio
[email protected]:~ $ cat /proc/asound/card1/pcm0p/sub0/hw_params
access: MMAP_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 441
buffer_size: 1764
hope this helps
ronnie
Return to “Media centres”
