So I was very anxious to see the result of the previous message
Which (old) version of Raspbian works with the mediabuild because I was having the exact same problems and whatever I did, fooling around with kernel configs etc etc I always got the "dvb_usb: disagrees about version of symbol rc_register_device" error and things did not work. On Ubuntu 16.04 and 18.04 no problems! But Raspbian is the challenge.
Having bought the August DVB-T230 which is actually also the Geniatech T230C2 ( idVendor=0572, idProduct=c68a:) described here
https://www.linuxtv.org/wiki/index.php/Geniatech_T230C2
Actually I got it to work once for a very short moment with a new kernel but was not able to reproduce it. It was after the './build', 'make install' and 'make rmmod' command but before the reboot. I did some manual 'insertmod' and 'modprobe' of a few modules and suddenly got it to work without error. Dit some scanning of frequencies and saw it was working! Then I did a reboot and I was having back the symbol problems again. Could not get it to work again.
I started my own investigation because I saw heaven but lost it again!
There is some discussions/misunderstanding about other media_builds and distro's which should support the Geniatech T230C2. Believe me, they do not work. I tried them all. The mediabuild of Crazycat is the only one that works because I saw it! (even if it was for a short time).
Libreelec was a tricky one! There were some rumours about a special build of Libreelec should supported this device and many more. I tried them all! Libreelec 9 and up does not support it. Libreelec 8.2.5 DOES recognize the device. Whaaw! Finally something! Everythings seems ok, the firmware is even loaded but when doing some real scanning it is not able to lock on any frequency. Waste of time!
Now the goodies! This is the setup that worked for me!
I installed the last version of raspbian (2019-04-08) and booted it.
Dont install the raspberrypi-kernel-headers! I will give you the latest one and that will not work.
You need to go to version 4.9.59-v7+.
How do you do this? Look at
https://github.com/Hexxeh/rpi-firmware/commits/master and scroll back until you see 'kernel: Bump to 4.9.59'. It was on committed on 29 Oct 2017. Sorry guys! Its a bit old but at least it works! Click the message and look for the 'git_hash' in the page. In this case it is '6820d0cbec64cfee481b961833feffec8880111e'
Then download this kernel version with Raspbian command
It will backup the old moduled and install version 4.9.59 of the kernel and its modules.
Reboot! It will boot into the new (old) kernel.
Now get the sources of this kernel by using the rpi-tool
wget https://raw.githubusercontent.com/notro/rpi-source/master/rpi-source
Get the sources and place them under /usr/src
sudo ./rpi-source --dest /usr/src
Check if onder /lib/modules/4.9.59-v7+/ the build and source links point to the right location.
lrwxrwxrwx 1 root root 14 Jun 23 14:09 build -> /usr/src/linux
lrwxrwxrwx 1 root root 14 Jun 23 14:09 source -> /usr/src/linux
And /usr/src should look like this:
lrwxrwxrwx 1 root root 55 Jun 23 14:09 linux -> /usr/src/linux-6820d0cbec64cfee481b961833feffec8880111e
drwxrwxr-x 25 root root 4096 Jun 23 14:09 linux-6820d0cbec64cfee481b961833feffec8880111e
If you have other sources installed this might mess things up. It should look like this!
Now its time for mediabuild
git clone https://bitbucket.org/CrazyCat/media_build
Compile it.
If everything compiled ok do the following:
sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/*
And then:
And
Reboot and check 'dmesg'
Mine looks like this.
[ 2.901994] usb 1-1.4: Product: EyeTV Stick
[ 2.902002] usb 1-1.4: Manufacturer: Geniatech
[ 2.902009] usb 1-1.4: SerialNumber: 161206
[ 3.027129] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.110577] systemd-journald[117]: Received request to flush runtime journal from PID 1
[ 3.403877] media: loading out-of-tree module taints kernel.
[ 3.406112] media: Linux media interface: v0.10
[ 3.443061] videodev: Linux video capture interface: v2.00
[ 3.443080] WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
[ 3.465191] WARNING: You are using an experimental version of the media stack.
Use it with care.
[ 3.505733] WARNING: You are using an experimental version of the media stack.
Use it with care.
[ 3.562698] dvb-usb: found a 'Mygica T230C2 DVB-T/T2/C' in warm state.
[ 3.831447] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 3.832142] dvbdev: DVB: registering new adapter (Mygica T230C2 DVB-T/T2/C)
[ 3.832163] usb 1-1.4: media controller created
[ 3.833580] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
[ 3.857268] i2c i2c-3: Added multiplexed i2c bus 4
[ 3.857283] si2168 3-0064: Silicon Labs Si2168-D60 successfully identified
[ 3.857292] si2168 3-0064: firmware version: D 6.0.1
[ 3.870039] si2157 4-0060: Silicon Labs Si2141 successfully attached
[ 3.870113] usb 1-1.4: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
[ 3.870143] dvbdev: dvb_create_media_entity: media entity 'Silicon Labs Si2168' registered.
[ 3.921220] Registered IR keymap rc-total-media-in-hand-02
[ 3.921438] rc rc0: Mygica T230C2 DVB-T/T2/C as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/rc/rc0
[ 3.921756] input: Mygica T230C2 DVB-T/T2/C as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/rc/rc0/input0
[ 3.922003] rc rc0: lirc_dev: driver dvb_usb_cxusb registered at minor = 0, scancode receiver, no transmitter
[ 3.922011] dvb-usb: schedule remote query interval to 100 msecs.
[ 3.922124] dvb-usb: Mygica T230C2 DVB-T/T2/C successfully initialized and connected.
[ 3.922247] usbcore: registered new interface driver dvb_usb_cxusb
And 'usb-devices' shows
T: Bus=01 Lev=02 Prnt=02 Port=04 Cnt=02 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0572 ProdID=c68a Rev=08.00
S: Manufacturer=Geniatech
S: Product=EyeTV Stick
S: SerialNumber=161206
C: #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=01 Prot=01 Driver=dvb_usb_cxusb
Please let me know if someone found a newer kernel to work with!
Enjoy!
