YeeeHaaa
XMBC + Logitech media server soft float
Mon Nov 19, 2012 11:02 pm
Hi.
I'm considering buying a Pi to host both LMS and XMBC.
I require the soft float code base as the hard float does not support (as far as I know) the Triode Spotify plugin which I'm dependant of.
As well it would be sweet to be able to use AirPlay which i know Raspbmc supports.
Is Raspbmc based on the hard float or soft float ABI? I would guess the hard float?
So if I would like to run XMBC on a soft float ABI - any tips how to continue? Is there a well performing, AirPlay enabled soft float stand alone XMBC package available somewhere?
Or is it possible to get hold of a soft float Raspbmc distro?
Otherwise I will be forced to buy two Pi's and dedicate one to Raspbmc and the other to LMS.
Return to “Media centres”
