OpenElec AVI resolution
Posted: Mon Nov 12, 2012 11:50 pm
HI,
I use OpenElec in my room on my monitor via HDMI and the avi's work fine.
Downstairs I have a TV that hdmi doesn't work on so I bought a HDMI to vga converter and the pi works fine with mkv's and mp4s(Not all though)
But avi's and some mp4's only play sound at my tv goes out of range.
I think the problem is the vga converter reports it can do every resolution the pi sends it a resolution for the avi file that it thinks the tv can handle it converts it to vga then the tv can not handle that resolution.( I think 1280*720 doesn't work)
But everything works fine with the mkvs(Actually human planet doesn't work)
So my question is, is they anyway to force the avis at a resolution or anyone else with a similar problem and solution.
Here is media info for files which DO NOT WORK
THESE BELOW WORK
General
Complete name : \\192.168.1.104\Videos\TV Shows\The IT Crowd\Season 1\the.it.crowd.s01e01.dvdrip.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 233 MiB
Duration : 23mn 15s
Overall bit rate mode : Variable
Overall bit rate : 1 398 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 23mn 15s
Bit rate : 1 253 Kbps
Width : 608 pixels
Height : 336 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.245
Stream size : 208 MiB (90%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 23mn 15s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 21.9 MiB (9%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.60 video frame)
Interleave, preload duration : 497 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
General
Complete name : \\192.168.1.104\Videos\TV Shows\Human Planet\human.planet.s01e07.720p.bluray.x264.mkv
Format : Matroska
Format version : Version 2
File size : 2.65 GiB
Duration : 58mn 40s
Overall bit rate : 6 457 Kbps
Writing application : x264.exe
Writing library : mkv2rls v1.3 (date: 2010 aug 28)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 4 946 Kbps
Width : 1 280 pixels
Height : 720 pixels
Frame rate mode : Variable
Original frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.215
Writing library : x264 core 114 r1900 60ef1f8
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=4946 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 58mn 40s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Stream size : 634 MiB (23%)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:10:05.760 : en:00:10:05.760
00:19:59.240 : en:00:19:59.240
00:30:43.320 : en:00:30:43.320
00:38:42.480 : en:00:38:42.480
00:48:46.640 : en:00:48:46.640
General
Complete name : \\192.168.1.104\Videos\TV Shows\The Simpsons\Season 4\Homer the Heretic.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 186 MiB
Duration : 23mn 1s
Overall bit rate : 1 130 Kbps
Movie name : Homer the Heretic
Genre : Comedy
Encoded date : UTC 2008-11-28 19:57:54
Tagged date : UTC 2008-12-31 03:19:13
tvsh : The Simpsons
tvsn : 4
tven : Homer the Heretic
tves : 3
Video
Format profile : Simple@L1
Format settings, BVOP : No
Codec ID : 20
Duration : 23mn 1s
Bit rate : 999 Kbps
Maximum bit rate : 4 686 Kbps
Width : 624 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 23.976 fps
Minimum frame rate : 23.964 fps
Maximum frame rate : 23.988 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.139
Stream size : 164 MiB (88%)
Writing library : Lavc51.40.4
Language : English
Tagged date : UTC 2008-11-28 20:12:56
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 23mn 0s
Bit rate : 128 Kbps
Maximum bit rate : 156 Kbps
Channel positions : Front: L R
Stream size : 21.1 MiB (11%)
Language : English
Text
Format : Apple text
Codec ID : text
Duration : 23mn 1s
Bit rate : 1 bps
Stream size : 144 Bytes (0%)
Language : English
General
Unique ID : 38917383699345430657616192132918310529 (0x1D4737288AD9C47E29C8E81AA5607681)
Complete name : \\192.168.1.104\Videos\TV Shows\South Park\Season 1\South Park - S01E03 - Volcano.mkv
Format : Matroska
File size : 84.1 MiB
Duration : 23mn 13s
Overall bit rate : 506 Kbps
Writing application : DivXMKVMux 3.4.1.0004
Writing library : libDivXMediaFormat 3.4.1.0004
Video
Format : AVC
Format profile : High@L4.0
MultiView_Count : 2
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=48
Duration : 23mn 13s
Bit rate : 368 Kbps
Width : 464 pixels
Height : 352 pixels
Frame rate mode : Constant
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.094
Stream size : 61.1 MiB (73%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 23mn 13s
Bit rate : 128 Kbps
Stream size : 21.3 MiB (25%)
Language : English
Default : Yes
Forced : No
