How to get work DVB T2 Hauppauge WinTV-HVR-935HD
Posted: Sun Oct 28, 2018 9:11 pm
by Radius
can someone help me, how to get the dual DVBT2 card to work on RPI3?
lsusb
ID 2040:b151 Hauppauge
I have found how to compile drivers for Ubuntu, but not for Raspbian.
http://www.hauppauge.com/pages/support/ ... x.html#ppa
There should be drivers:
https://github.com/b-rad-NDi/Ubuntu-med ... el-builder
In my case, I need to make these steps (download kernel 4.15)
https://www.raspberrypi.org/documentati ... uilding.md
then apply these patches?
https://github.com/b-rad-NDi/Ubuntu-med ... nic-4.15.0
How? Download them (where) and like this page says?
https://www.raspberrypi.org/documentati ... atching.md
cat 0001-Linuxtv.org-media-tree-sync-2018-04-30-04-20.patch | patch -p1
and thats all? No extra configuration?
Thanks for advice.
Radius
Re: How to get work DVB T2 Hauppauge WinTV-HVR-935HD
Posted: Sun Oct 28, 2018 9:52 pm
by AltxF4
I just wrote a post that should help you a bit, but it has not been approved yet.... depending on what your hardware is composed of. What is the output from dmesg?
Posted: Fri Nov 02, 2018 9:38 am
by Radius
nothing special:
[ 2.011500] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 2.144024] usb 1-1.4: New USB device found, idVendor=2040, idProduct=b151
[ 2.144035] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.144043] usb 1-1.4: Product: Hauppauge Device
[ 2.144052] usb 1-1.4: Manufacturer: Hauppauge
[ 2.144060] usb 1-1.4: SerialNumber: xxxxx
R.
Posted: Sun Nov 04, 2018 7:55 pm
by walterav1984
Solution easier than you might think, the next raspbian release will have out of the box support for this tuner (except firmware if needed).
https://github.com/b-rad-NDi/Ubuntu-med ... -435699342
Instructions for RPI3
Start without your USB tuner attached and use a recent updated raspbian image and update your kernel to 4.19 with the following command:
sudo apt-get update
sudo apt-get -y upgrade
sudo apt-get -y dist-upgrade
sudo BRANCH=next rpi-update #use capitals since command is case sensitive!
sudo apt-get -y install tvheadend #available in raspbian repo since DVB-t2 HAT ;-)
sudo reboot
#After finishing reboot type
dmesg
#insert your usb tuner
dmesg
#notice any thing about missing firmware.fw, google your firmware and download it
wget http://someadress/examplefirmware.fw
sudo cp examplefirmware.fw /lib/firmware/
sudo reboot
#enjoy your mainline hauppauge linux driver!
Posted: Wed Sep 25, 2019 1:44 pm
by Devon City
Im having a problem with this tuner, I think it is FW releated.
It works fine with TVheadend but i do not get any HD chanels only the SD ones and the radio.
Any ideas? - i dont know if there would be a different FW i need to use to the one it recommended when i used dmesg
Im using a Rasbeerypi 4 2GB - With Raspbian.
Posted: Wed Sep 25, 2019 6:35 pm
by Pulsar33
Give a try to Kaffeine, no ?
It works well for me with DVB TV pHAT and with Cynergy T-Stick+ Black (USB)
Regards
Pulsar33
Posted: Wed Sep 25, 2019 7:03 pm
by johndavies
I'll begin by admitting that i know nothing about your device for tuning in TV signals. I assume that you need to download from your local transmitter. The ones that are stored on the Pi date back to about 2013 and do not include HD channels. You need to find a more modern version. Look at https://git.linuxtv.org/dtv-scan-tables.git/log and get more up to date transmiiter details. You should see about 15 Hd channels including two of my favourites, the Smithsonian Channel and PBS America. From that you can make a channels.conf file. You can play these HD channels through VLC. This is what you need to enter for PBS America. You will need to look up the channel details for your local transmitter :
vlc dvb-t2://frequency=754000000:bandwidth=8 :program=45360 (figures for the Sutton Coldfield transmitter)
The space between 8 and the colon in front of program=45360 i.e. "bandwidth=8 :program=45360" is critical. On my SD card I have stopped using tvheadend because it interfered with my attempts to find other ways of tuning in TV and radio channels.
Posted: Fri Sep 27, 2019 4:47 pm
by snowballEarth
Try installing firmware:
wget http://palosaari.fi/linux/v4l-dvb/firmware/Si2168/Si2168-B40/4.0.25/dvb-demod-si2168-b40-01.fw
sudo mv dvb-demod-si2168-b40-01.fw /lib/firmware
sudo reboot
This works on two other dvb-t2 models of Hauppauge tuners so good chance it works with yours. Otherwise, getting SD channels but no HD channels could be a poor reception issue
Posted: Fri Oct 04, 2019 1:40 pm
by Devon City
Ive have a go tonight and let you know.
It might im just not looking at the correct Mux infomation, but as i am in a freeview lite area, im stuggerling to find what i need to use. Im on the st thomas exeter transmitter. None of lists online include this one. :-(
