Radius
How to get work DVB T2 Hauppauge WinTV-HVR-935HD
Sun Oct 28, 2018 9:11 pm
can someone help me, how to get the dual DVBT2 card to work on RPI3?
lsusb
ID 2040:b151 Hauppauge
I have found how to compile drivers for Ubuntu, but not for Raspbian.
http://www.hauppauge.com/pages/support/ ... x.html#ppa
There should be drivers:
https://github.com/b-rad-NDi/Ubuntu-med ... el-builder
In my case, I need to make these steps (download kernel 4.15)
https://www.raspberrypi.org/documentati ... uilding.md
then apply these patches?
https://github.com/b-rad-NDi/Ubuntu-med ... nic-4.15.0
How? Download them (where) and like this page says?
https://www.raspberrypi.org/documentati ... atching.md
cat 0001-Linuxtv.org-media-tree-sync-2018-04-30-04-20.patch | patch -p1
and thats all? No extra configuration?
Thanks for advice.
Radius
AltxF4
Re: How to get work DVB T2 Hauppauge WinTV-HVR-935HD
Sun Oct 28, 2018 9:52 pm
I just wrote a post that should help you a bit, but it has not been approved yet.... depending on what your hardware is composed of. What is the output from dmesg?
Radius
Fri Nov 02, 2018 9:38 am
nothing special:
[ 2.011500] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 2.144024] usb 1-1.4: New USB device found, idVendor=2040, idProduct=b151
[ 2.144035] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.144043] usb 1-1.4: Product: Hauppauge Device
[ 2.144052] usb 1-1.4: Manufacturer: Hauppauge
[ 2.144060] usb 1-1.4: SerialNumber: xxxxx
R.
walterav1984
Sun Nov 04, 2018 7:55 pm
Solution easier than you might think, the next raspbian release will have out of the box support for this tuner (except firmware if needed).
https://github.com/b-rad-NDi/Ubuntu-med ... -435699342
Instructions for RPI3
Start without your USB tuner attached and use a recent updated raspbian image and update your kernel to 4.19 with the following command:
sudo apt-get update
sudo apt-get -y upgrade
sudo apt-get -y dist-upgrade
sudo BRANCH=next rpi-update #use capitals since command is case sensitive!
sudo apt-get -y install tvheadend #available in raspbian repo since DVB-t2 HAT ;-)
sudo reboot
#After finishing reboot type
dmesg
#insert your usb tuner
dmesg
#notice any thing about missing firmware.fw, google your firmware and download it
wget http://someadress/examplefirmware.fw
sudo cp examplefirmware.fw /lib/firmware/
sudo reboot
#enjoy your mainline hauppauge linux driver!
Return to “Media centres”
