SSH problems
Posted: Mon Aug 27, 2018 9:05 pm
by rob27
Im building a NAS with my raspberry 3B, but im having problems on the software side. Lets consider my two machines, A and B, both Windows-os, running ssh command in WSL, Ubuntu
Problem n°1: A,B -> Raspby
Im trying to establish an SSH connection to my raspberry but when i type the password and enter it get stuck. Running the command with verbosity, it seems to stop on
channel:0 open confirm rwindow 0 rmax 32768
Same thing trying with PuTTY
Sometimes it get until the command line, but it doesnt allow me to type anything in it.
Problem n°2: Raspby ->A,B
Using VNC on A im able to connect to my raspby, and there from terminal i want to establish an ssh to B, but the connection time out every time
How can i set A,B and the raspberry to run ssh properly?
I know:
-That it can be run once per time, es A->raspby, B->raspby and not A, B->raspby, or the opposite
-It worked, on both machines
-I already had the same issue, I resolved messing with the key_ssh and finished to rewrite my sd because i messed a little bit much. I want to avoid this
