Diaoul
XBMC .debs and packaging instructions
Wed Oct 31, 2012 8:27 pm
A while ago I started a packaging suite for XBMC hosted here : https://github.com/Diaoul/xbmc-rbp-packaging
Instructions are in the README if you want to compile it by yourself on your RPi
You can download precompiled .debs from https://github.com/Diaoul/xbmc-rbp-packaging/downloads
What's in:
  • PVR Addons
  • CEC support
  • NFS support
Feel free to contribute to add more features to those .debs
Enjoy
joshmosh
Re: XBMC .debs and packaging instructions
Fri Nov 02, 2012 7:01 am
it seems that this is just what I was looking for.
I have been playing around with my Raspi and now have it running 24*7 with a number of services (CUPS, lightttpd, calibre etc) on it, which only use tiny fractions of CPU. So, the server could do much more :-)
The other XBMC distributions come with an already setup system, which would mean for me that I had to set up all my servers again from scratch - which I would like to avoid.
I'll give your pack a try. Thank you for this contribution to the Raspi community !
Cheers
Joshi
alias_neo
Fri Nov 02, 2012 6:07 pm
Looks good, I'm going to give this a go now once I uninstall the current version I'm running since it seems to be stuck at ~94% CPU load all the time.
http://2byt.es - Just my two bytes - RPi - Android - Arduino - Blog
alias_neo
Fri Nov 02, 2012 6:41 pm
alias_neo wrote:Looks good, I'm going to give this a go now once I uninstall the current version I'm running since it seems to be stuck at ~94% CPU load all the time.
Ok, I got your debs installed but seeing some strange behaviour. If it's set to 1080p I can only see the top left quarter of it, I've checked the settings, it's running 1080p and my monitor says 1080p so I don't know what's going on.
Diaoul
Sun Nov 04, 2012 10:23 pm
Press * on your keyboard (mine is AZERTY). I think there's a shortcut to minimize XBMC.
alias_neo
Sun Nov 04, 2012 11:19 pm
Diaoul wrote:Press * on your keyboard (mine is AZERTY). I think there's a shortcut to minimize XBMC.
Nevermind, I got it to work correctly by removing the .xbmc folder from my home dir, left over from my previous install.
The real thing bothering me now is that I have tried several different builds and they all idle at ~94%-98% CPU. It's driving me crazy. I used to have a build that idled at ~15%-20% CPU and I could live with that.
I've turned off the RSS feed, no change, and I've tried the dirty region thing, again, no change. I'm out of ideas.
The other real issue I see is that these builds fail to play a lot of videos I previously had running fine on an older install of Raspbian/XBMC on my old RPi (256M) before I sent it back. I just get my console (tty) back, and when I move the mouse I get the OSD over the top of my console, but no actual video.
Diaoul
Thu Nov 08, 2012 10:10 am
Feel free to improve the packaging suite if you find some options that could improve performances.
I'll upload the build I'm currently using from the 5th of November, maybe that'll help.
alias_neo
Thu Nov 08, 2012 10:18 am
Diaoul wrote:Feel free to improve the packaging suite if you find some options that could improve performances.
I got it built myself, using the same (or as close as I can remember) config I used before, but I just get a segfault when I try to start it.
I'd be very interested in trying your current build if you say it's working, so I can figure out if it's my environment rather than the build of XBMC.
Return to “Media centres”
