em.rexhepi
gst-launch-1.0 problem saving sound and transcoding
Tue Jul 03, 2018 11:19 am
I'm a newbie on gstreamer and its documentations are a headache for me, I'm trying for 3 days now to make smth. work. Just succeeded to save the stream in h264 file with no audio also with bugs which I don't have any idea how to fix.
I need to trans-code with: bit-rate 350kb/s, frame-rate to 25/1, frame dimensions 640 × 480 or 480p.
I have the mpeg2 license setup and working.
Every help from you guys is really appreciated.
Raspberry pi 3B
os details:
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
Input stream details:
gst-discoverer-1.0 http://192.168.0.184:8090/
Topology:
  container: MPEG-2 Transport Stream
    video: MPEG-2 Video
    audio: MPEG-2 AAC
      audio: MPEG-4 AAC
Properties:
  Duration: 99:99:99.999999999
  Seekable: yes
  Tags:
      audio codec: MPEG-4 AAC
      video codec: MPEG-2 Video
Have a range of failing pipes which i tried to do I'm going to post only this working one.
My half wokring pipe:
gst-launch-1.0 --gst-debug=*:3 souphttpsrc location="http://192.168.0.184:8090/" \
! decodebin name=demux demux. \
! mux. matroskamux name=mux streamable=true demux. \
! queue \
! videoconvert \
! videoscale \
! omxh264enc\
! h264parse \
! filesink location=test.h264
The debug result:
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
0:00:00.784478878  6389  0x1e8f090 WARN        mpegtspacketizer mpegtspacketizer.c:2268:mpegts_packetizer_pts_to_ts: Not enough information to calculate proper timestamp
0:00:00.784587263  6389  0x1e8f090 WARN        mpegtspacketizer mpegtspacketizer.c:2268:mpegts_packetizer_pts_to_ts: Not enough information to calculate proper timestamp
0:00:00.784876117  6389  0x1e8f090 WARN        mpegtspacketizer mpegtspacketizer.c:2268:mpegts_packetizer_pts_to_ts: Not enough information to calculate proper timestamp
0:00:00.784924972  6389  0x1e8f090 WARN        mpegtspacketizer mpegtspacketizer.c:2268:mpegts_packetizer_pts_to_ts: Not enough information to calculate proper timestamp
0:00:00.784958669  6389  0x1e8f090 WARN        mpegtspacketizer mpegtspacketizer.c:2268:mpegts_packetizer_pts_to_ts: Not enough information to calculate proper timestamp
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
0:00:01.103954076  6389  0x1b072c0 FIXME           videoencoder gstvideoencoder.c:630:gst_video_encoder_setcaps:<omxh264enc-omxh264enc0> GstVideoEncoder::reset() is deprecated
0:00:01.139033618  6389  0x1d260c0 ERROR            omxvideoenc gstomxvideoenc.c:656:gst_omx_video_enc_handle_output_frame:<omxh264enc-omxh264enc0> No corresponding frame found
0:00:01.208101451  6389  0x1d260c0 WARN                   qtmux gstqtmux.c:1698:gst_qt_mux_start_file:<mp4mux0> downstream did not handle seeking query
Even though it has these errors it saves the video, but the video only.
Return to “Media centres”
