Motoi
Fusion between two raspberry for a plex media server
Tue Jun 26, 2018 6:47 am
Hey,
I created a plex media center on a raspberry pi 3B+. Works perfectly but a little bit too slow in my opinion, I know the problem isn't from the quality of the network (whitch is excellent).
I came in possession of a pi0w, and I wondered if it was possible to use it as a sort of an external processor, or something like that to boost up my plex server.
Thanks for you're time :)
drgeoff
Re: Fusion between two raspberry for a plex media server
Tue Jun 26, 2018 8:40 am
Short answer. No.
Longer answer. In what way is the 3B+ setup too slow for you?
Motoi
Thu Jun 28, 2018 6:50 am
Thanks for your answer,
Well, It works fine but I got to have an excellent network when playing a media, the conversion usually take too much time and timeout.
And some devices (like the ps4) can't even play the media and timeout also.
I saw there was a system of cluster that could be set up using a pi0, what is it exactly ?
Edit : forgot to specify a few things. All the movies and tv shows are stored on an external hard drive (self powered). The server is pretty consistant : 290 movies and 2 tv shows approximately
Thu Jun 28, 2018 7:22 am
Clustering / Parallel Processing / Distributed Computing is an interesting subject but you need software which is written for this purpose and still will run into I/O limitations.
The Raspberry Pis with Ethernet uses a USB/Ethernet Controller Chipset on the single USB 2 Bus to provide the 2/4 USB Ports and Ethernet, so you are running into I/O limitations.
What do mean by conversion ? surely your media files are in a format which your devices can play ??
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
Motoi
Thu Jun 28, 2018 7:49 am
What's the I/O limitation ?
And PMS isn't written to do that ?
Plex offer a service that convert your media (from 720p to 480p for exemple) so you can read them even with a slower network
Well my files are normal, .avi, .mkv or .mp4, works fine usually when directly plugged via USB
Thu Jun 28, 2018 8:20 am
If you have Ethernet Connection and USB Hard Drive on the same RPi, as explained above, they are sharing the single USB2 BUS.........
https://github.com/wnielson/Plex-Remote ... /issues/56
adieu
Return to “Media centres”
