Geeman2000
LibreELEC/Kodi 04/18 - Can CEC be disabled?
Wed Jun 06, 2018 1:49 am
Hi All,
Just set up Pi 3 and it is connected as an input to ONKYO receiver through to Samsung panel. For some reason the Samsung switches to a different input (away from the connection to the receiver resulting in a no signal screen) at random times and must be reset to the correct input (at which time it says "disconnecting Anynet device".
I would just be happy just to disable the CEC but what I have found in searching for this doesn't seem to match this version of software.
Any suggestions?
DarrenHill
Re: LibreELEC/Kodi 04/18 - Can CEC be disabled?
Wed Jun 06, 2018 9:29 am
From memory, if you go to
System -> Settings -> System -> Input Devices -> Peripherals -> CEC adapter
(or something like that, under the Estuary skin) you should have the options page for CEC support, including the option to disable it.
Geeman2000
Wed Jun 06, 2018 9:59 am
Spot on!
Should be all good now.
Thanks so much for the assistance.
Return to “Media centres”
