I am not sure this is the right section, apologize if not.
I am building a media center with multiple raspberry that play video in sync (master/slave).
I am writing my app in C++ so I don't want use the turing machine solution because is in python, but I use its dbuscontrol.sh script to interact with omxplayer via dbus.
The communication works, but when I use setposition command that would set the video time at specific position (in microseconds), it sets at greater position than the value I send.
For example if I launch:
dbuscontrol.sh setposition 11560000Code: Select all
dbuscontrol.sh statusAnyone know why happen this or have any other solution to control omxplayer position via c++?
Thanks.
Add some log of the same command called 3 times
08:35:27 T:1736748884 DEBUG: OMXReader::SeekTime(11560) - seek ended up on time -2147483648
08:35:27 T:1736749192 DEBUG: OMXClock::OMXStop
08:35:27 T:1736749987 DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
08:35:27 T:1736884697 DEBUG: OMXClock::OMXMediaTime set config OMX_IndexConfigTimeCurrentVideoReference = 11560000.00
08:35:27 T:1736896025 DEBUG: Seeked 11560002 11560000 11560000
08:35:27 T:1736896100 DEBUG: Normal M:11560000 (A:0 V:-4503599627370496) P:1 A:-11.56 V:0.00/T:0.20 (0,0,1,0) A:0% V:0% (0.00,0.00)
08:35:27 T:1736896151 DEBUG: COMXPlayer::HandleMessages - player started RESET
08:35:27 T:1736896332 DEBUG: OMXClock::OMXReset audio / video : 0 / 1 wait mask 0->2 state : 2->1
08:35:27 T:1736896550 INFO: CDVDPlayerVideo::Decode dts:8274933 pts:8341667 cur:8341667, size:1529
08:35:27 T:1736896603 DEBUG: OMXVideo::Decode VDec : setStartTime 8.341667
08:35:27 T:1736896712 DEBUG: Normal M:11560000 (A:0 V:8341667) P:1 A:-11.56 V:-3.22/T:0.20 (0,1,1,0) A:0% V:0% (0.00,0.00)
08:35:30 T:1740330514 DEBUG: OMXReader::SeekTime(11560) - seek ended up on time -2147483648
08:35:30 T:1740331328 DEBUG: OMXClock::OMXStop
08:35:30 T:1740332258 DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
08:35:30 T:1740446402 DEBUG: OMXClock::OMXMediaTime set config OMX_IndexConfigTimeCurrentVideoReference = 11560000.00
08:35:30 T:1740458286 DEBUG: Seeked 11560003 11560000 11560000
08:35:30 T:1740458345 DEBUG: Normal M:11560000 (A:0 V:-4503599627370496) P:1 A:-11.56 V:0.00/T:0.20 (0,0,1,0) A:0% V:0% (0.00,0.00)
08:35:30 T:1740458395 DEBUG: COMXPlayer::HandleMessages - player started RESET
08:35:30 T:1740458533 DEBUG: OMXClock::OMXReset audio / video : 0 / 1 wait mask 0->2 state : 2->1
08:35:30 T:1740458787 INFO: CDVDPlayerVideo::Decode dts:16616600 pts:16683333 cur:16683333, size:1427
08:35:30 T:1740458836 DEBUG: OMXVideo::Decode VDec : setStartTime 16.683333
08:35:30 T:1740458906 DEBUG: Normal M:11560000 (A:0 V:16683333) P:1 A:-11.56 V:5.12/T:0.20 (0,0,1,1) A:0% V:0% (0.00,0.00)
08:35:30 T:1740458957 DEBUG: Resume -11.56,5.12 (0,0,1,1) EOF:0 PKT:(nil)
08:35:30 T:1740458990 DEBUG: OMXClock::OMXSetSpeed(1.00) pause_resume:1
08:35:32 T:1741639642 DEBUG: OMXReader::SeekTime(11560) - seek ended up on time -2147483648
08:35:32 T:1741639792 DEBUG: OMXClock::OMXStop
08:35:32 T:1741640117 DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
08:35:32 T:1741719106 DEBUG: OMXClock::OMXMediaTime set config OMX_IndexConfigTimeCurrentVideoReference = 11560000.00
08:35:32 T:1741729824 DEBUG: Seeked 11560002 11560000 11560000
08:35:32 T:1741729877 DEBUG: Normal M:11560000 (A:0 V:-4503599627370496) P:1 A:-11.56 V:0.00/T:0.20 (0,0,1,0) A:0% V:0% (0.00,0.00)
08:35:32 T:1741729928 DEBUG: COMXPlayer::HandleMessages - player started RESET
08:35:32 T:1741730070 DEBUG: OMXClock::OMXReset audio / video : 0 / 1 wait mask 0->2 state : 2->1
08:35:32 T:1741730283 INFO: CDVDPlayerVideo::Decode dts:8274933 pts:8341667 cur:8341667, size:1529
08:35:32 T:1741730337 DEBUG: OMXVideo::Decode VDec : setStartTime 8.341667
08:35:32 T:1741730400 DEBUG: Normal M:11560000 (A:0 V:8341667) P:1 A:-11.56 V:-3.22/T:0.20 (0,1,1,0) A:0% V:0% (0.00,0.00)As you can see all 3 times it setStartTime at wrong time and every time at different time, 8.341667 and 16.683333
