1080i AVC (h264) Tv recordings no longer work - Black Screen
Posted: Thu Oct 18, 2012 12:14 am
I have a lot of UK TV recordings.
The sd recordings are in .ts mpeg 2 format. They work fine with mpeg2 hardware decoder after bought license.
The hd recordings are in .ts format. Windows says they are mpeg2 also but I am not sure.
This is the media info for one of the files:
===================== General =====================
Complete name : \\HOMESERVER\Recorded TV\ITV1 HD\The X Factor\The X Factor - 2012-10-13.ts
Format : MPEG-TS
File size : 11.1 GB
Duration (ms) : 2h 25mn
Total bitrate : 11.0 Mbps
===================== Video =====================
MenuID/String : 137 (0x89)
Format : AVC
Format info : Advanced Video Codec
Format profile : Main@L4.0
Use of CABAC : Yes
RefFrames : 4 frames
Format settings - GOP : M=1, N=24
Codec Id : 27
Bitrate : 9 987 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Aspect ratio : 16:9
Framerate : 25.000 fps
Colorimetry : YUV
Colos space : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
ScanOrder/String : Top Field First
Bits/(Pixel*Frame) : 0.193
Stream size : 10.1 GB (91%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
===================== Audio #1 =====================
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec Id : 4
Bitrate mode : Constant
Bitrate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Video_Delay/String : -229ms
Stream size : 199 MB (2%)
===================== Audio #2 =====================
Format : AC-3
Format info : Audio Coding 3
Format settings mode extens : CM (complete main)
Codec Id : 6
Bitrate : 256 Kbps
ChannelPositions : Front: L R
Bit depth : 16 bits
Video_Delay/String : -308ms
Stream size : 266 MB (2%)
Language : English
===================== Text #1 =====================
Format : DVB Subtitle
Codec Id : 6
Language : English
===================== Text #2 =====================
Id : 107 (0x6B)-888
Format : Teletext Subtitle
Language : English
So are these hd recordings in mpeg2 format ? It says mpeg but then it says AVC .
Also when playing on xbmc it comes up as: D(Video: h264 (Main)
The other thing is these videos no longer play in xbmc with the latest updates/changes. I'm not sure whats causing them to not work now.
If you try using xbian 0.83 or raspbmc rc 5 all you get is a black screen, or a grey screen but you can hear the sound.
If you go back to an earlier release like xbian 0.62 which is running linux kernel 3.1.9 they work fine and play well.
Any ideas whats happened in the latest changes and why these no longer work.
If
Format : MPEG-TS
File size : 11.1 GB
Format : AVC
Use of CABAC : Yes
Codec Id : 27
Aspect ratio : 16:9
Colorimetry : YUV
Colos space : 4:2:0
Bit depth : 8 bits
Format : MPEG Audio
Codec Id : 4
Bitrate : 192 Kbps
Format : AC-3
Codec Id : 6
Bitrate : 256 Kbps
Bit depth : 16 bits
Language : English
Codec Id : 6
Language : English
Id : 107 (0x6B)-888
Language : English
If
