jpec
RasPyPlayer - a lightweight media center
Sun Oct 14, 2012 1:59 pm
I'm designing a small and fast media center for the Pi. I'm writing it in Python3 and Tkinter. It uses omxplayer as backend for playing files.
It is currently a prototype but it works (scanning library, searchs and playing files). Please feel free to try it and report me bugs, suggestions, patches, etc!
Sources and bug tracker are on github : https://github.com/jpec/RasPyPlayer
Cotopaxi
Re: RasPyPlayer - a lightweight media center
Wed Sep 18, 2013 11:23 pm
First thanks for the player, it works well.
Just one question: how do you add specific options to the player like -t on --align center --no-ghost-box to see the subtitles centered and without the grey box?
PS: sorry I know I am late, I hope you will see this post
jpec
Thu Sep 19, 2013 6:07 am
Hi.
Ok, i'll do it in the next days!
Cotopaxi
Thu Sep 19, 2013 6:41 am
Thanks, this is the missing feature, for me. Let us add any option we want please, not only the one concerning the subtitles. ;)
And would it be possible to use the player without database, just to read a video ?
jpec
Thu Sep 19, 2013 6:56 am
Cotopaxi wrote:Let us add any option we want please, not only the one concerning the subtitles. ;)
I'll add an entry in the config window to permit adding any omxplayer option.
Cotopaxi wrote:And would it be possible to use the player without database, just to read a video ?
It's not the objective. But easy to realize. :ugeek:
Cotopaxi
Thu Sep 19, 2013 7:11 am
jpec wrote: I'll add an entry in the config window to permit adding any omxplayer option.
Perfect. :)
jpec wrote:It's not the objective. But easy to realize. :ugeek:
Yeah I know, and it is not the most important change, don't worry.
But it is just that all of my videos are on my USB key mounted in /media/key/ and there are several folders. I indicate to RaspyPlayer that my video files are in /media/key but he doesn't see all the files in the different folders, just the files that are in the same folder as the file I am reading.
Is it normal ?
And last question : is the video type filter used?
Thanks for the answers! ;)
jpec
Thu Sep 19, 2013 7:17 am
Cotopaxi wrote: Yeah I know, and it is not the most important change, don't worry.
Is it normal ?
No. It should scan all directories except these in the exclude folders list.
Cotopaxi wrote:And last question : is the video type filter used?
Yes.
ciancmatt
Thu Sep 19, 2013 7:27 am
How can I get it for my pi?
New to the pi
Cotopaxi
Thu Sep 19, 2013 7:35 am
jpec wrote: No. It should scan all directories except these in the exclude folders list.
Then I don't know what goes wrong. :D
ciancmatt wrote:How can I get it for my pi?
Download it here: http://raspyplayer.org/
ciancmatt
Thu Sep 19, 2013 8:16 am
Here are some suggestions. Should be able to play DVDs from an external DVD drive and from flash media.
New to the pi
jpec
Fri Sep 20, 2013 7:57 am
ciancmatt wrote:Here are some suggestions. Should be able to play DVDs from an external DVD drive and from flash media.
Yes. Replace one URL by the path of the DVD mount point.
gaara92
Mon Sep 23, 2013 8:46 am
Bonjour,
J'essaie d'installer Raspyplayer, mais au lancement de l'applicatrion, j'ai un message d'erreur:
[email protected] ~ $ raspyplayer
*** Starting the Player ***
*** Creating Configuration GUI ***
  File "/usr/local/bin/raspyplayer", line 1217, in <module>
    player = Player()
  File "/usr/local/bin/raspyplayer", line 840, in __init__
    self.start()
  File "/usr/local/bin/raspyplayer", line 852, in start
    self.displayConfig()
  File "/usr/local/bin/raspyplayer", line 958, in displayConfig
    self.cfg.display(self)
  File "/usr/local/bin/raspyplayer", line 390, in display
    self.fill()
  File "/usr/local/bin/raspyplayer", line 421, in fill
    self.ui_out.insert(0, self.OUT)
  File "/usr/lib/python3.2/tkinter/__init__.py", line 2412, in insert
    self.tk.call(self._w, 'insert', index, string)
_tkinter.TclError: wrong # args: should be ".3063335568.3063335728 insert index text"
Que dois-je faire pour que cela fonctionne?
Merci
jpec
Mon Sep 23, 2013 9:37 am
C'est quelle version : 2.4, 2.5 ou 2.6?
nickr
Tue Sep 24, 2013 8:44 am
Seems to be reinventing the XBMC wheel. What do you see as the advantages over XBMC?
jpec
Tue Sep 24, 2013 8:49 am
nickr wrote:Seems to be reinventing the XBMC wheel. What do you see as the advantages over XBMC?
Not at all. XBMC is a full mediacenter and it even do the coffee.
RasPyPlayer is *very* light and simple. It's only able to play movies or tv stream.
jpec
Wed Sep 25, 2013 8:24 am
Player, a simple video player :
New version of Raspyplayer :
Download it on http://raspyplayer.org/ !!!
LightEmittingDude
Thu Dec 26, 2013 3:28 am
Thanks for this.
Is it possible to switch audio tracks while playing? Or to tell the player to open the video file (mkv) with non-default audio selected? I'm using the player app not the mc.
Thanks again and merry christmas!
Return to “Media centres”
