bruno123
Kodi does not start on PI 3
Sat Sep 09, 2017 3:45 pm
Hi
I have Kodi on a standard SD that I created for my PI Zero, no problem at all on PI Zero.
Now I bought a PI 3, and while the SD with RASPBIAN (previously on the Pi Zero) works wothout any troubles, the SD with Kodi does not work at all; at the beginning when the plug is connected, I see the green light but after a second it disappears and nothing happens, nothing on the screen, nothing on the wifi network, dead.
Any idea?
Bruno
drgeoff
Re: Kodi does not start on PI 3
Sat Sep 09, 2017 10:46 pm
What Kodi?
LibreELEC
OpenELEC
OSMC
XBian
Raspbian with Kodi
RetroPie
Recalbox
Compiled from source
mahjongg
Sun Sep 10, 2017 12:11 pm
Old OS versions created before a newer PI was launched do not boot on said newer PI, but the latest OS will also boot on all older PI's.
Imperf3kt
Sun Sep 10, 2017 10:59 pm
You don't have the experimental video driver enabled, do you? I have noticed Kodi fails to work with that.
Stop plugging your fan directly into the GPIO 5v
https://www.electronics-tutorials.ws/power/transient-suppression.html
bruno123
Tue Sep 12, 2017 4:44 pm
drgeoff: It should be OSMC (directly installed on SD).
Imperf3kt: I don't think that I have the experimental video driver enabled, how can I check it ?
dom
Tue Sep 12, 2017 5:25 pm
OSMC has separate images for Pi0/1 and Pi2/3. You need to run the correct image.
For help in transferring existing setup to the new Pi2/3 image you should ask here:
https://discourse.osmc.tv/
bruno123
Tue Sep 12, 2017 6:27 pm
Thank you for your answer.
I am surprised that other application (eg Openhab) are compatible, while kodi no.
So I need two different SDs for changing the hardware.
Return to “Media centres”
