prioryjim
Raspbmx XBMC and PlexXBMC problems
Wed Oct 03, 2012 6:52 am
See original comments scattered in post
http://www.raspberrypi.org/phpBB3/viewt ... 23&t=18499
I have a fairly beefy Linux server running Plex media server.
This has a number of identical format videos in a directory. ( Star Trek, sad I know ).
I have a Windows 7 laptop with XBMC and PlexXBMC configured.
This plays all the videos from Plex without problem.
I originally loaded Raspbmc onto an old class 4 SD I had.
Installed XMBC and PlexXBMC
It would play some of the videos.
And some it tried to play but failed.
At this point I think I might have made a small change to the network !!!!!
So I used a class 10 SD card installed XBMC/PlexXBMC and tried again
This wouldn't play any of the videos.
Swapped back to the class 4 SD that used to partially work.
But now it would play none of the videos.
I need to investigate logs etc when I get some spare time.
Possibly network issues.
Anyone had similar problems or even tried using XBMC/PlexXBMC
Jim
prioryjim
Re: Raspbmx XBMC and PlexXBMC problems
Thu Oct 04, 2012 4:46 am
No body using ,,
raspxbmc , Plexbmc and Plex
Did a bit more investigation.
Some vids play some don't , all the same format.
I suspect it's not that it won't play them, more accessing in the correct manner.
There are errors to the effect that it can't access some http urls.
Will investigate more, perhaps renaming some files.
Jim
MattPoat
Sun Oct 28, 2012 11:27 am
Another RaspBMC & Plex user here. Everything was working fine for me until this morning. Now everytime I try to start Plex up on my Pi, the thing hangs on the xbmc background screen with no text & no response to remote control inputs. Bloody annoying but at least Plex still works on my ios devices, so I can use Airplay.
Matthew
"I'm selling these fine leather jackets"
Return to “Media centres”
